Real Analysis: Stolz–Cesàro Proof
Gib Z
1. Let xn and yn be sequences in R with yn+1 > yn > 0 for all natural numbers n and that yn→∞.
(a) Let m be a natural number. Show that for n > m
\frac{x_n}{y_n} = \frac{x_m}{y_n} + \frac{1}{y_n} \sum_{k=m+1}^{n} (x_k - x_{k-1})
(b) Deduce from (a) or otherwise that
|\frac{x_n}{y_n}| \leq |\frac{x_m}{y_n}| + \sup_{k>m} | \frac{ x_k - x_{k-1} }{ y_k - y_{k-1} } |
(c) Assuming \frac{x_n-x_{n-1}}{y_n-y_{n-1}} \to 0, show x_n/y_n \to 0.
(d) Assuming \frac{x_n-x_{n-1}}{y_n-y_{n-1}} \to L, show x_n/y_n \to L.
N/A
(a) was fine.
(b) Would the question be more correct to use sup k>m+1 instead, since a k-1 index is in the inside expression?
I'm not sure if this was the right thing to do as the question probably intended the sum to remain unsimplified, but I replaced it with xn-xm.
Using the triangle inequality and that y is strictly increasing so that yn-ym < yn, we get
| \frac{x_n}{y_n} | \leq | \frac{x_m}{y_n} | + | \frac{x_n-x_m}{y_n-y_m} |
Then I'm not really sure what I can validly do after that.
(c) If (b) is assumed, then if we take the limit of both sides, it reduces to the statement that | \frac{x_n}{y_n} | - | \frac{x_m}{y_n} | \leq 0 holds true for large n.
I don't think that's the right direction to go, certainly since it seems to imply x is decreasing when that was never given. Don't know what to do.
(d) No idea, but if I had (c) this one would probably be similar.
Has anyone got any hints? I'm still stuck.
|\frac{x_n}{y_n}| \leq |\frac{x_m}{y_n}| + \sup_{k&gt;m} | \frac{ x_k - x_{k-1} }{ y_k - y_{k-1} } |
\left| \frac{x_n}{y_n} \right| \leq | \frac{x_m}{y_n} | + | \frac{x_n-x_m}{y_n-y_m} |
you probably already know this, but the 2nd equation doesn't imply the first because sup(all that stuff) could be smaller than \left| \frac{x_n-x_m}{y_n-y_m} \right|
The most obvious path is to prove that
\sup_{k&gt;m}\left|y_n\frac{\Delta x_k}{\Delta y_k} \right| \geq \left| \sum_{k=m+1}^{n} \Delta x_k\right|
and then apply triangle inequality.
First, restate it as an existence question, remove the sup and ask: does there exist a k that makes the inequality true?
[STRIKE]An idea:
It reduces to finding m+1\leq k \leq n such that
\frac{y_n}{\Delta y_k}\geq n-m (1)
and
\Delta x_k \geq \frac{|x_n-x_m|}{n-m} (2)
It is easy to to find a k that satisfies each condition individually, but I can't see how to find one that satisfies both simultaneously =(
[/STRIKE]
edit: the above approach won't work, I found a counterexample to it.
For c),
to find N such that \frac{x_n}{y_n}&lt;\varepsilon for n>N,
first find an m such that \frac{ \Delta x_k }{\Delta y_k } &lt; \frac \varepsilon 2 for k>m, then use part b) and finish it off.
My mind started thinking clearly and I figured these out finally. If anyone's interested in the solutions send me a PM and I'll post them here.
boboYO, I didn't see the edit until just now, my final solution for (c) didn't make any use of (b) and was quite long =[ Could you tell me how we could have used (b) to finish it off. When I see it I bet I'll kick myself.
see what you think of this
let \Delta x_j = x_j-x_{j-1}
then, let k>m be the the supremum index, then
| \frac{\Delta x_k }{ \Delta y_k }| \geq | \frac{\Delta x_j }{ \Delta y_j }|, \forall j&gt;m
rearranging, knowing that \Delta y_j &gt; 0, then summing from m+1 upto n:
| \frac{\Delta x_k }{ \Delta y_k }| \sum \Delta y_j \geq \sum |\Delta x_j |\geq |\sum \Delta x_j|
so
\sup_{k&gt;m}| \frac{\Delta x_k }{ \Delta y_k }| \geq |\frac{x_n-x_m}{y_n-y_m}|\geq |\frac{x_n-x_m}{y_n}| \geq |\frac{x_n}{y_n}| - |\frac{x_m}{y_n}|
then for c) choose M such that
\frac{x_m-x_{m-1}}{y_m-y_{m-1}} &lt; \epsilon, \forall m&gt;M
then for n,m>M
|\frac{x_n}{y_n}| \leq |\frac{x_m}{y_n}| + \epsilon
x_m is just a number, and as y_n is unbounded as n increases, we should be able to choose N>M so that for all n>N
|\frac{x_m}{y_n}|\leq \epsilon
then for n>N>M
|\frac{x_n}{y_n}| \leq 2\epsilon
which should be pretty close...
this part threw me for a bit above
but I'm thinking maybe the continuous analogue is something like the mean value theorem, except that the maximum gradient must be >= the average
not 100% there is no holes...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
