Recharging a battery when Lightbulb and TV are in parallel
The discussion centers on calculating the time needed for a wind generator to recharge a battery while powering a light bulb and a TV in parallel. The light bulb has a resistance of 100Ω and operates at 100 V, while the TV consumes 100 W. The total energy required for both appliances over 200 minutes is 2.4 MJ. The wind generator supplies 10 A at 100 V, resulting in a power output of 1000 W. The conclusion is that it takes approximately 40 minutes of wind power to recharge the battery, confirming the calculations based on energy conservation principles.
Jtwa
In a household, the wife reads a book that uses a light bulb that has a resistance of 100Ω and is connected to a 100 V line while the husband watches a TV that draws 100 W of power. They do these actives for 200 mins. Power comes from a wind generator that charges batteries. The wind supplies 10 amperes at a voltage of 100 V.
How long must the wind blow to recharge the battery.
V=IR
P= V2/r
Modeled the circuit to have the light bulb and tv in parrallel. Using the power equation, the tv also has 100Ω of resistance which doesn't make to much sense to me.
Power is J/s so we know that 200 min is 12000s which tell us 1.2 MJ is required to charge the battery.
Think about W consumed and W generated, that may make it clearer for you. You don't need a circuit diagram to solve this. You are missing an equation for wind power - what is it? That is key to seeing the solution in the simplest way. Write three power equations -
TV Power =
Light Power =
Wind Power =
That should help.
I see two potential answers - one (trivial) answer assuming the wind is blowing while the appliances are drawing power, and a different answer assuming the wind only starts blowing after the appliances have been turned off.
Likes Jtwa
TV Power =
Light Power =
Wind Power =
That should help.
Thank you for the response.
The missing equation is P=IV which helps us calculate the Wind Power
I've calculated the following:
TV Power = 100W
Light Power = 100W
Wind Power = 1000W
Since a watt is a J/s then the TV and Light require 2.4x106 J
Divide power required by wind power and we get 2400 s which is 40 minutes? Does that sound correct?
40 mins is correct.
You can also get to same answer using
Energy out = Energy In
200W * 200mins = 1000W * 40mins
Ok so the Watt.min isn't an SI unit but that doesn't matter.
Likes Jtwa
