Recirculation Current in an Inductor
  • Thread starter Thread starter EigenFunctions
    Current Inductor
EigenFunctions
I am trying to derive an equation for a simple inductive circuit which is the serial connection of an inductor (L), a resistor (R) and a Diode (D). The initial condition is a current flowing (Izero). Using Kirchhoff's law, the basic equation is:
Vdiode=Vinductor+Vresistor
The inductor is L*di/dt, the resistor is i*R and a simple model for a diode is n*VT*ln(i/Is+1) where n, VT and Is are constants. So the differential equation becomes:
L*di/dt + i*R = n*VT*ln(i/Is+1)
Putting it in standard form:
di/dt + [i*R/L - (n*VT/L)*ln((i/Is)+1)] = 0
I don't know how to deal with the expression in the square brackets.
Any suggestions?
Thanks,
EigenFunctions
PS - the diode function comes from Idiode(v) = Is*(exp(v/(n*VT)-1) as used in spice. Later, I will sum in an additional term for a diodes ohmic resistance.
Solve numerically the way Spice would. Also check your signs. Shouldn't all terms in your ODE be positive?
Inductor is energy source re: Recirculation Current in an Inductor
You are correct, since the energy is stored in the inductor, it should be (see the updated attachment):
Vinductor = Vdiode + Vresistor
It seems like there should be a way to solve it, maybe with a Taylor series or something like that.
Thanks,
EigenFunctions
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
