ollybabar
- 3
What is the algebra required to rewrite the nth term of: (sum from n=0 to infinity) of (pi^n)/(3^n+1) in geometric form?
ollybabar said:What is the algebra required to rewrite the nth term of: (sum from n=0 to infinity) of (pi^n)/(3^n+1) in geometric form?
A geometric series is a sequence of numbers where each term is found by multiplying the previous term by a fixed number called the common ratio. It follows the form a, ar, ar^2, ar^3, ... where a is the first term and r is the common ratio.
A geometric series can be recognized by looking for a constant ratio between consecutive terms. If each term is multiplied by the same number, then it is a geometric series.
The formula for finding the sum of a geometric series is S = a / (1 - r), where S is the sum, a is the first term, and r is the common ratio.
A geometric series will converge if the absolute value of the common ratio (|r|) is less than 1. If |r| is greater than or equal to 1, the series will diverge.
Yes, a geometric series can have negative terms as long as the common ratio is also negative. The terms will alternate between positive and negative, and the series may still converge or diverge depending on the value of the common ratio.
