Reconstruction Primordial Fluctuations from Temperature Anisotropy
The discussion focuses on reconstructing primordial fluctuations from temperature anisotropy in the Cosmic Microwave Background (CMB) using a linear filter. The method involves minimizing the variance between the filtered field and the underlying primordial fluctuations, leading to the derivation of a specific filter solution. Participants suggest consulting advanced textbooks and review papers for deeper insights into the methodology. One contributor notes that the process resembles constructing a Wiener filter but seeks clarification on the derivation from the partial differential equation. The conversation emphasizes the importance of reaching out to the paper's authors for expert guidance.
maverick280857
Reconstructing Primordial Fluctuations from Temperature Anisotropy
Hi
For a summer project, I am required to read the paper "Measuring Primordial Non-Gaussianity in the Cosmic Microwave Background", Komatsu et al (http://arxiv.org/abs/astro-ph/0305189v2).
On page 3, the following arguments describe the method of reconstructing primordial fluctuations from temperature anisotropy:
(The point I am stuck at is given below and is boldfaced...you may want to scroll down skipping the background, which I have included to define the notation.)
The harmonic coefficients of the CMB anisotropy are given by
a_{lm} = \frac{1}{T}\int d^{2}\hat{n}\Delta T(\hat{n})Y_{lm}^{*}(\hat{n})
They are related to the primordial fluctuations as
a_{lm} = b_{l}\int r^{2}dr \left[\Phi_{lm}(r)\alpha_{l}^{adi}(r) + S_{lm}(r)\alpha_{l}^{iso}(r)\right] + n_{lm}
where \Phi_{lm}(r) and S_{\lm}(r) are the harmonic coefficients of the fluctuations at a given comoving distance r = |x|, b_{lm} is the beam transfer function and n_{lm} is the harmonic coefficient of noise.
Here,
\alpha_{l} \equiv \frac{2}{\pi}\int k^{2}dk g_{Tl}(k)j_{l}(kr)
where g_{Tl} is the radiation transfer function of either adiabatic (adi) or isocurvature (iso) perturbation; j_{l}(kr) is the spherical Bessel function of order l.
This is where I'm stuck:
Next, assumuming that \Phi(x) dominates, we try to reconstruct \Phi(x) from the observed \Delta T(\hat{n}). A linear filter, O_{l}(r), which reconstructs the underlying field, can be obtained by minimizing variance of difference between the filtered field O_{l}(r)a_{lm} and the underlying field \Phi_{lm}(r). By evaluating
\frac{\partial}{\partial O_{l}(r)}\left\langle\left|O_{l}(r)a_{lm}-\Phi_{lm}(r)\right|^{2}\right\rangle = 0
one obtains a solution for the filter as
O_{l}(r) = \frac{\beta_{l}(r)b_{l}}{C_{l}}
where the function \beta_{l}(r) is given by
\beta_{l}(r) \equiv \frac{2}{\pi} \int k^{2}dk P(k) g_{Tl}(k)j_{l}(kr)
and P(k) is the power spectrum of \Phi.
(Here C_{l} \equiv C_{l}^{th}b_{l}^{2} + \sigma_{0}^2 includes the effects of b_{l} and noise, where C_{l}^{th} is the theoretical power spectrum.)
I can't see how the authors have obtained the solution for the filter from the partial differential equation. I would be grateful if someone could shed light on this step.
Thanks in advance.
Vivek.
Astronomy news on Phys.org
This is a very specific question. I would suggest that you try a few advanced textbooks (although you probably have done this already?). Other than that, review papers, in this case a review of CMB physics and measurement, often go into more detail about methods that other papers do not have the space for.
Hopefully someone else will be able to provide a more useful answer, but that is as much as I can suggest.
My advice would be to email the author of the paper - they should be able to offer the best advice.
Thank you matt.o and Wallace.
I believe this is a construction of a Wiener filter, but I am not sure how the PDE has resulted in the given solution. I have mailed the author of the paper.
What is the expectation taken over?
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
