A Recovering Wavefunction in Periodic Ab Initio Calculations
bsmile
In ab initio calculations for periodic systems, only an irreducible K grid is used for calculation, and consequently only those K points have their wavefunction calculated. My question is, how to recover wavefunction at other K points not included in the irreducible K grid? Similar questions to the density matrix.
I hear the term "irreducible K grid" for the first time.
Likes BvU
sorry, I should be more careful towards my terms, it should be something like irreducible K wedge in the first Brillouin Zone.
Ah, I see.
I suppose you get the other wedges applying the elements of the point group of your crystal to the wavefunctions.
In fact, there is a very general theorem from group theory, the orbit-stabilizer theorem. If G is the full point group of your crystal and H is the little group of the point in K space, then a point in your K wedge will mapped to #G/#H points in total K space. "#" means here the number of elements of the group. E.g. the little group of the Gamma point is G, i.e. H=G, so the gamma point is invariant, while the little group of a general point, not coinciding with a special point is H=1, so there will be #G points formed from it.
Yes, I understand there is point group symmetry operation on how to related one K point to the other equivalent ones, but I don't know how to transform the eigen-wavefunction for (n,K) where n is band indices? I believe this could be done. A further question is, would the transformation depend on the choice of basis set, say planewave basis or atomic orbital basis set (say contracted Gaussian basis set)?
You can use the general expression for transformation for this. So if a point transforms as ##r'=Rr##, a function transforms as ##\psi'(r)=\psi(R^{-1}r)##. Use the Bloch theorem and the form of your wavefunctions to work out how they transform. E.g. ##exp(ik^TR^{-1} r)## can be written as ##exp(ik'^Tr) ## with ##k'=(k^TR^{-1})^T=Rk ##. Be careful here when direct and reciprocal lattice vectors are used.
Thanks, I understand here ##\psi## is a scalar, thus a geometric transformation does not change it, while dot product being a scalar is also not affected. What if ##\psi## is a spinor with its axis along discrete z direction while the target K has a direction arbitrary in space, or another quantity differing from wavefunction but carrying indices in angular momentum, say a local orbital density matrix ##\rho_{px,py}(K)##, to be transformed into arbitrary target K direction?
Then you have to transform the spinor/vector too: ##v'(r)=D_Rv(R^{-1}r)##. Where ##D_R## is a transformation matrix for the spinor/vector.
14K
