Rectified Current Through an Inductor
In summary, the conversation discusses finding the magnetomotive force (mmf) of an inductor using NI (turns multiplied by amperes). The setup involves an AC power supply set at 24 VAC going through a full wave rectifier and into an inductor with a resistance of 47 Ohms. The conversation also touches on the RMS average current through the inductor and the need to specify all component values before simulating real waveforms.
akaf244
TL;DR Summary
rectified current through inductor
Hello, I need to find the magnetomotive force (mmf) of an inductor using NI (turns multiplied by amperes). The set up is pretty simple, AC power supply set at 24 VAC goes through a full wave rectifier (4 diodes) and into an inductor. If the inductor has a resistance of 47 Ohms, it looks like this (ignore Ls and Rs)...
I have spent a few hours and a lot of different equations trying to figure out the current flowing through the inductor. I know it will look something like this...
but can anyone explain to me how they are graphing the current??
Thank you! (screenshots from: https://www.plexim.com/academy/power-electronics/diode-rect-ind-load )
Welcome to PF.
The Vgrid, 24 VAC, will have a peak voltage of Vgrid * Sqrt( 2 ).
Two bridge diodes need to conduct and will have a forward voltage of say, Vpn each.
The rectified output voltage will peak at; Vo = ( Vgrid * Sqrt( 2 )) - ( 2 * Vpn ).
The rectified waveform is close to a sine so the RMS value will be; Vrms = Vo / sqrt( 2 ).
The inductor will phase shift the DC current in proportion to the inductance.
The total output resistance will be; Ro = Rload + Rind.
The RMS average current through the inductor will be; Io = Vrms / Ro.
Hello, thank you for the response. How can I find Rload and Rind now? Shouldnt i be using Z? (Z=sqrt(R^2+(wL)^2)).Thank you.
Your question is unclear. Are you trying to find average RMS values or instantaneous values as a function of time?
If RMS, be aware that the sqrt(2) applies only for sinusoidal waveforms. This case in non-sinusoidal waveforms.
You have specified resistance of the inductor as; Rind = 47 ohms.
You must identify the load resistance; maybe the box there with 47 ohms is for the load?
The rectified waveform no longer has a fundamental sinewave, so in the frequency spectrum it has 2'nd and higher even harmonics of the original fundamental. The reactance of the inductor cannot be specified as a single value, it must be evaluated for each harmonic.
The current is not a single AC sinewave, it is a DC current with even harmonic ripple. The ripple is an inverse function of the inductance. You will need to consider Vind = L * di/dt. Consider the extremes; If the inductance was zero, the current would be resistive and follow the voltage without delay. If the inductance was infinite the current would be pure DC, with the average RMS value.
All components must be specified before real waveforms can be simulated. You have not specified those values because they were not provided by your reference.
1. What is rectified current through an inductor?
Rectified current through an inductor refers to the direct current (DC) component of the current that flows through an inductor in a circuit. It is the portion of the current that remains after the alternating current (AC) component has been removed.
2. How is rectified current through an inductor different from regular current?
Rectified current through an inductor is different from regular current in that it is a unidirectional flow of electrons, while regular current is a bidirectional flow. Rectified current is also smoother and has a constant magnitude, while regular current fluctuates in magnitude and direction.
3. What causes rectified current through an inductor?
Rectified current through an inductor is caused by the inductance of the inductor, which is a property that resists changes in current. When an alternating current flows through an inductor, the inductance causes the current to lag behind the voltage, resulting in a DC component.
4. How is rectified current through an inductor used in circuits?
Rectified current through an inductor is commonly used in power supplies and voltage regulators to convert AC power to DC power. It is also used in filters to smooth out the current and remove any unwanted AC components.
5. Can rectified current through an inductor be reversed?
No, rectified current through an inductor cannot be reversed. The inductor's inductance will always cause the current to lag behind the voltage, resulting in a unidirectional flow of electrons. To reverse the current, the polarity of the voltage source would need to be reversed.
  • Electrical Engineering
