Balancing Redox Equations: NO3- + Ag in Acidic Solution
  • Thread starter Thread starter vsage
    Redox
The discussion focuses on balancing the redox equation involving nitrate (NO3-) and silver (Ag) in an acidic solution. The proposed half reactions are Ag → Ag+ + e- and e- + NO3- + 2H+ → NO2 + H2O, leading to the balanced equation 2H+ + NO3- + Ag → Ag+ + NO2 + H2O. Participants confirm the accuracy of the half reactions and the overall balanced equation. Key tips include balancing non-oxygen and non-hydrogen atoms first, followed by oxygen with H2O, and hydrogen with H+. The conversation emphasizes the importance of practice to improve confidence in redox equations.
vsage
This is the 2nd problem on a HW sheet I have. I don't have any particular problems with it but I'm just making sure I'm doing these right:
Complete (add H20, H+ or OH- as appropriate) and balance the following equations. Show all half reactions.
a. NO_3^- + Ag \rightarrow Ag^+ + NO_2 (acidic)
Half reactions I found to be:
-Ag\rightarrow Ag^+ + e^-
-e^- + NO_3^- + 2H^+ \rightarrow NO_2 + H_2O
making the balanced reaction
2H^+ + NO_3^- + Ag \rightarrow Ag^+ + NO_2 + H_2O
Any thoughts? I'm pretty iffy on redox equations. Thanks
that looks correct. I did these last term and if my memory serves me well, that is the correct answer.
Regards,
Nenad
Your half reactions and balanced equation look correct. Just a couple of things to keep in mind when balancing redox equations:
1. Always balance atoms other than oxygen and hydrogen first, then balance oxygen by adding H2O, and finally balance hydrogen by adding H+.
2. Remember to balance the charges on both sides of the equation. In this case, the charges are already balanced, but for more complicated reactions, you may need to add electrons to balance the charges.
Overall, it looks like you have a good understanding of balancing redox equations. Keep practicing and you will become more confident in your skills. Good luck with the rest of your homework!
