How Does Gear Count Affect the Efficiency and Size of Gearboxes?
The discussion centers on the efficiency and size of gearboxes in relation to gear count and ratios. Using two gears with a high gear ratio is generally more economical and lighter than using three gears with lower ratios, especially when the required ratio exceeds 5.2. For very high reduction ratios, planetary gearboxes can provide significant reductions in a single stage, making them more compact and lightweight compared to conventional multistage gearboxes. The choice between gear configurations depends on various factors such as power, speed, size, efficiency, and cost constraints. Ultimately, understanding these complexities requires in-depth knowledge, as highlighted by the recommendation of Dudley's Handbook of Practical Gear Design.
Datt
I have a question what is a difference or advantage for using two gears with high gear ratio or using three gears with lower gear ratio.Is there any advantage.
Welcome to PF.
It depends on the overall ratio required. What ratio do you need?
The lightest weight and most economic gearbox will have pairs of gears, that each give a reduction ratio of about three. That comes about by considering the size and strength of the teeth.
If the ratio is greater than about 5.2 use more than one pair.
For one, adding an extra gear between two gears does not alter the gear ratio; It only changes the direction of rotation of the final gear.
To alter the final gear ratio, you need four gears, the middle two being on the same shaft. This adds extra friction losses and also extra inertia. Compared to a two-gear gear set, the final rotation is still reversed.
But the larger the gear ratio is, the more difficult it becomes to respect the combined design constraints like pressure angle, contact ratio, or undercut.
Baluncore said:
Welcome to PF.It depends on the overall ratio required. What ratio do you need?
That heavily depends on the gearbox.
For very high reduction ratios, planetary gearboxes can achieve much larger reductions than that in a single stage, which can end up more compact and lighter than a multistage conventional gearbox with a similar reduction ratio. Size and weight also depends very heavily on torque handling capacity, though of course that'll scale at least fairly similarly regardless of which gearbox design you chose.
There is no simple answer to your question. A complete answer depends on the ratio, power, speed, size constraints, efficiency constraints, cost constraints, and more. If you get a copy of Dudley's Handbook of Practical Gear Design, and read the entire book, you will be able to understand just how difficult it is to answer your question. The book is available from Amazon: https://www.amazon.com/dp/0367649020/?tag=pfamazon01-20. I read an earlier edition, and highly recommend it for completeness and readability.
Planetary gears are used on coaxial shafts where side forces need to be minimised. The planetary reduction unit can still be smaller and lighter again when an axial stack of planetary gears is used, rather than only one high-ratio planetary stage.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
