Reflection of a mechanical wave
When a mechanical wave reflects off a fixed support, it undergoes a phase change of π radians. This can be qualitatively understood by considering a one-dimensional wave on a stretched string, where the wave equation describes the motion. At the fixed point, the sum of the incident and reflected waves must equal zero, leading to the conclusion that the reflected wave is the negative of the incident wave. This cancellation at the fixed wall illustrates the phase reversal. Thus, the reflection of a mechanical wave at a fixed boundary results in a phase shift of π.
gandharva_23
when a mechanical wave is reflected by a fixed support it experiences a phase change of pi ... without getting into maths can i qualitatively prove this ? i cannot analyse how the forces will be acting .
Science news on Phys.org
let's assume this is a one-dimensional wave problem (wave on a stretched out string). the diff eq. describing it is likely:
c^2 \frac{\partial^2 y}{\partial x^2} = \frac{\partial^2 y}{\partial t^2}
a general solution is
y(x,t) = y_1(x-ct) + y_2(x+ct)
where c is the wavespeed and y_1(.), y_2(.) can be anything and have to be determined by initial conditions. y_1(x-ct) is a wave moving in the +x direction and y_2(x+ct) is a wave moving in the -x direction and the two waves just add up (superimpose). now let's say that your string is anchored at x=0. that means that
y(0,t) = y_1(-ct) + y_2(ct) = 0
for all time t. now about the only way for that to happen is if
y_1(-ct) = -y_2(ct)
that means, at x=0, that the wave that is moving in one direction has to be the exact negative of the wave moving in the other direction for them to add to zero and they have to add to zero because of the "fixed support". reversing the polarity is the same as a phase change of \pi radians.
The easiest way to see the pi pahse change is that the incident and reflected wave mus cancel at the fixed wall. This means the reflected wave must be the negative of the incident wave.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
