, regarding breathable material
  • Thread starter Thread starter Detlen1
    Material
The discussion focuses on creating a breathable work suit that combines elements of both indoor and outdoor wear, utilizing lightweight materials similar to MILATEX™ or GORE-TEX® but less robust. The aim is to develop a uniform that is water-repellent yet comfortable, resembling a wetsuit but suitable for everyday use, particularly for EMS personnel. The contributor mentions a breathable poncho made from 100% polypropylene as a potential inspiration for the suit's design. Additionally, there is a request for ideas on implementing an auto-unlock feature for doors, similar to technology used in some cars. The project is still in development, and further suggestions are welcomed.
Detlen1
Eager young mind at work
im trying to come up with a concept of a suit that you ware at work, the main purpose is to let you have in on (like a uniform) but with a different design and material i have done some research but let's face it unless there is a different browser out there that I am not aware of; Google and Yahoo is not cutting it for me. (short of calling/investigating different corps.)
Now this is the issue. I am looking for an inside/outside ware sort of like MILATEX™ or GORE-TEX® material but just less robust and more like a tight woven cotton/polyester suit however it needs to have some of the same traits as the other do like water repellent but not too dense that it affects your body temp. example more inside ware than a true affective outside ware, kind of like a wet suit but more affective in a common sense. if there are any ideas i would be most grateful.
Problem is that this sort of specific information is worth real money and much of it isn't in the public domain.
I have an ultra-lightweight and breathable poncho made by DriDucks. It says it's made from 100% polypropalene, which has been around for decades. It's quite comfortable, and if if there were a single piece suit, say coveralls made of the stuff, I think it would work quite well. It might be a little warm, but nice.
ok ty, I’m trying to make something like a star trek suit but NOT, and i have some ideas into making it into a uniform for EMS and so forth however more like under uniform, so more inside ware but outer ware too just not heavy duty. so ill take a look, if any other ideas come to mind please let me know, its still a work in progress.
on the same note can anyone explain and give me an idea how to make a auto unlock for doors and such, like (i forget what car(s) can auto unlock a car door when u get in proximity to it) auto unlock. hope I’m not being to vague.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
