How Fast Must an Electron Travel to Excite a Hydrogen Atom?
  • Thread starter Thread starter ke0nGz
The discussion centers on calculating the speed required for an electron to excite a hydrogen atom, with the first excitation energy specified as 10.2 eV. The kinetic energy of the electron, expressed as 1/2 mv^2, must equal the excitation energy to achieve this. The electron charge/mass ratio and constants like Planck's constant and the speed of light are provided for reference. The calculated speed of the slowest electron necessary for this excitation is 1.9 x 10^6 m/s. The conversation emphasizes the relationship between kinetic energy and excitation energy in atomic physics.
ke0nGz
i hav problem solving this.. help please?
The 1st excitation energy of hydrogen atom is 10.2eV
calc the speed of the slowest electron that can excite a hydrogen atom..
(electron charge/mass ratio e/m = 1.7 x 10^11 C kg-1)
C(speed of light ) is 3 x 10^8 ms-1
h(planks constant) is 6.6 x 10 ^ -34 Js
thats all the given information
the answer is 1.9 x 106ms-1
The kinetic energy of the electron gets transferred to the excitation energy of the hydrogen atom.
Can you express that statement in an equation?
p.s. Welcome to PF.
er..
hf = work function energy?
1st excitation energy is work function energy?
speed of the slowest electron is the hf oso = 1/2 mv^2?
You're half-way correct, since 1/2 m v^2 is the kinetic energy of the electron.
What is the excitation energy of the atom?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
