Related Rates: Is the Derivative of a Changing Circle's Area Constant?
  • Thread starter Thread starter rook_b
    Rate
rook_b
Let A be the area of a circle of radius r that is changing with respect to time. If dr/dt is constant, is dA/dt constant? Explain.
A = 2(pi)r^2
dA/dt = 2(pi)(r)*dr/dt
I can't decide. You see if dr/dt is constant and multiplied by 2(pi) then dA/dt must be constant. But, r, what is r? It must be that 'r' is a function of time, I think. Or, r is an initial value that grows as the rate dr/dt. A constant rate times a constant should yield a constant rate, but multiplied by a variable it will yield a variable rate. I hate r.
... :biggrin:
If dr/dt is any constant other than 0, yes, r is a variable and so dA/dt is a variable. Don't hate r- it's harmless.
Ah, thank you once again HallsofIvy.
Hmm, one more question. Where does time t come into this? Specifically, it seems that r must be a function of time t so is r really r(t). That is, if I wanted to graph this as time vs dA/dt. A short confirmation by anyone would be appreciated.
Yes, r is a function of t. dr/dt is the derivative of that function with respect to t. Since dr/dt does not equal 0, r(t) is not constant. We know that dr/dt does not equal 0 because the problem says that the radius of the circle is changing with respect to time.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
