How Fast Are the Man and Woman Moving Apart in the Related Rates Problem?
  • Thread starter Thread starter Rasine
    Related rates
Rasine
A man starts walking north at 6 ft/s from a point P. Five minutes later, a woman starts walking south at 2 ft/s from a point 500 ft due east of P. At what rate are the people moving apart 30 min after the woman starts walking?
so i was ableto set up a right triangle using the x-y plane (y being north and x being east)
so i was trying to relate the components with distance^2=x^2+y^2
then where i differientate i get dd/dt=dx/dt+dy/dt
i know dy/dt=8 and i want to know dd/dt
there dx/dt=0 becuase there is no change in x...x is always 500 ft
so would dd/dt=dy/dt=8 ?
Then you differentiated wrong! If dd^2= x^2+ y^2 then, differentiating, 2dd d(dd)/dt= 2x (dx/dt)+ 2y (dy/dt). Since dx/dt= 0,
2dd d(dd)/dt= 2y(dy/dt) so dd d(dd)/dt= 2y dy/dt. Now, 30 minutes after the woman starts walking (35 minutes after the man starts walking) what are dd and y?
Very close but not exactly!
Pyramid shaped tank...?
Does anyone know how to do this problem on related rates?:
The base of a pyramid-shaped tank is a square with sides of length 8 meters, and the vertex of the pyramid is 8 meters above the base. The tank is filled to a depth of 2 meters, and water is flowing into the tank at the rate of 4 cubic meters per minute. Find the rate of change of the depth of water in the tank. (Hint: the volume of a pyramid is given by V=1/3bh, where b is the base area and h is the height of the pyramid)
Please, please, please! Do not "hijack" someone else's thread for a different question. Start your own thread- it's not that difficult!
Okay, can you determine how h is related to b for different heights of the water?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
