Relating Work Function and Wavelength
Barium has a work function of 2.48 eV, which determines the longest wavelength of light that can cause electron emission. The calculations involve using the equations W = hf and E = hc/λ to find the frequency and wavelength. After determining the frequency to be approximately 5.99e14 Hz, the wavelength is calculated as 5.02e-7 m. The relationship between frequency and wavelength is inversely proportional; as frequency increases, wavelength decreases. The discussion confirms that the calculations are on the right track.
ri0t
Barium has a work function of 2.48 eV. What is the longest wavelength of light that will cause electrons to be emitted from barium?
W = hf○
hf = W + Ek
E = hf = hc/λ
1 eV/1.6e-19 C = 2.48/X
X = 3.97e-19
W=hf○
3.97e-19/6.63e-34f
f=5.99e14 Hz
Now I'm lost...Anybody care to help? :)
So what's the relationship between frequency and wavelength? You've already used it (look at equation 3).
I think I've figured out the problem using v=fλ, 3.0e8 = 5.98e14λ, λ=5.02e-7m.
Also the answer to your question is that as frequency increases, wavelength decreases.
Would be awesome if you could tell me I'm on the right track, and of course if I'm not, as well.
Yes, you are right.
Thanks much.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
