Relation between centre of mass and center of gravity?
The center of mass and center of gravity are equivalent in a uniform gravitational field, such as near the Earth's surface. For most objects, including tall ones, the gravitational acceleration is considered constant at approximately 9.81 m/s². This means that the center of mass (CM) coincides with the center of gravity (CG) for practical purposes. The distinction becomes relevant only in non-uniform fields or for very large objects where gravitational variation can occur. Understanding this relationship simplifies many physics problems related to balance and stability.
manoj mishra
What is the Relation between center of mass and center of gravity, please compare with simple example. Bco'z i am very confused about it
In a non zero uniform gravitational field, they are the same. An oject on planet Earth has the same cm as cg, neglecting any insignificant changes in g for even extremely tall objects (g is assumed constant at 9.81 m/sec^2 near Earth's surface).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
