weezy
- 92
- 5
I've just started with statistical mechanics and arrived at the part where they relate entropy to the number of microstates for a given system. The derivation starts of by adding an amount of heat ##\delta Q## to a system and observing the resulting change in internal energy : $$\delta U = \delta Q - P\delta V$$
where internal energy ##U## is given by $$ U = \sum _i N_iE_i $$ where ##N_i## is the no. of particles with energy ##E_i##. Also: $$\delta U = \sum _i \delta N_iE_i + \sum _i N_i\delta E_i $$ Now it's stated here that
>the change ##\delta E_i## in energy level is only possible if volume changes
and hence: $$\sum _i N_i\delta E_i = \sum _i N_i\frac{\partial E_i}{\partial V}\delta V = -P\delta V $$ where ##P=-\frac{\partial U}{\partial V}##
Using all equations we can see $$\delta Q = \sum _i E_i\delta N_i $$
I'm having trouble understanding why is change in energy level ##\delta E_i## only possible with change in volume. Any type of energy adding to the system should cause a change in energy level but what does it have to do with volume?
Also I'm not understanding what change in energy level means here actually. To me a particle can have any energy ##E_i## and when some energy is added to the system and let's assume that particle happens to absorb some of the energy it gets promoted to a higher energy level ##E_i+\epsilon## and but the previous energy level ##E_i## still exists. Only now ##N_i - 1## particles occupy energy ##E_i##. So what exactly has changed here?
