Relation between exponentially distributed random variables and Poisson(1)
rukawakaede
Hi,
Suppose X_1, X_2,\cdots be an independent and identically distributed sequence of exponentially distributed random variables with parameter 1.
Now Let N_n:=\#\{1\leq k\leq n:X_k\geq \log(n)\}
I was told that N_n\xrightarrow{\mathcal{D}}Y where Y\simPoisson(1).
Could anyone give me some directions for this problem? I am totally out of mind.
Thanks.
For fixed n, the condition
X_k = log ( n )
gives you a probability for each of the exponential random variables to be included in the count. So, what distribution does that mean N has in terms of n, k and that probability?
The limit of that distribution as n goes to infinity should then be Poisson.
Hi rukawakaede! :smile:
Like sfs01 suggested, you first need to calculate the distribution of Nn. That is, you'll need to know probabilities like P\{N_n=k\}. Let's get you started on that calculation: (assume that 0\leq k\leq n)
P\{N_n=k\}=P\left(\bigcup_{A\subseteq \{1,...,n\},~|A|=k}\{X_i\geq \log(n),i\in A; X_i<\log(n), i\notin A\}\right)
Now try to calculate that using that the Xi are iid.
rukawakaede said:
Hi,
Thanks.
If you write it as N_n=\sum_{k=1}^nI(X_k \geq \log(n)) it should be easy to show that N_n is binomial with parameter 1/n. To show convergence I'd use characteristic functions.
May I know what your I means?
Could you please tell me more about the N_n?
Uh, well, I think bpet's method is a bit easier than what I had in mind. So I suggest following him.
Anyway, the I there means a characteristic function, thus
N_n=\sum_{k=1}^n{I_{X_k^{-1}[\log(n),+\infty[}}
where
I_A(\omega)=\left\{\begin{array}{c}0~\text{if}~\omega\notin A\\ 1~\text{if}~\omega\in A\\ \end{array}\right.
where
If in that case, isn't the I an indicator function?
I still can't see why N_n is a binomial distribution.
Yes.
[/QUOTE]
Because every indicator function IA has a Bernouilli distribution. Indeed, it becomes 0 with chance P(Ac) and it becomes 1 with chance P(A). So it is Bernouilli.
Now, the sum of Bernouilli functions is a binomial function, i.e. Bern(p)+...+Bern(p)=Bin(n,p).
Also note that Bern(p)=Bin(1,p).
All you have to do now is figure out what p is here...
micromass said:
Yes.Because every indicator function IA has a Bernouilli distribution. Indeed, it becomes 0 with chance P(Ac) and it becomes 1 with chance P(A). So it is Bernouilli.
is the p=(1/2)n since each indicator function can be 1 or 0?
No, the p of IA is P(A), since IA has a chance of P(A) of becoming 1.
Take for example throwing a weighted coin such that the chance on head is 1/3. Then it is Bernouilli(1/3) distributed. But by your reasoning, it would be Bernouilli(1/2) since the coin has two sides. It's not always so that the probability is simple 1/(number of outcomes)
Hi I guess I misunderstood the meaning for p. Could you please explain again what actually p is?
Well, a Bernouilli(p) variable is a random variable X such that X takes on two values 0 and 1, and the chance that X takes on 1 is p, and the chance that X takes on 0 is 1-p.
