Relationship between radiation flux and count rate of a scintillator
The relationship between radiation flux and the count rate of a scintillator is influenced by the luminosity of the source and the distance from it, with the formula F = L/(2πr²) defining the flux. The count rate, measured as the number of scintillations over time, depends on the efficiency of the detector, which varies with the material and size of the scintillator. While the efficiency is often assumed to be linear within certain energy ranges, significant nonlinearities can occur outside these ranges. To calculate the expected count rate for a specific detector, one must consider the product of the flux, the detector's cross-sectional area, and its efficiency. Understanding these factors is crucial for accurately determining the count rate in practical applications.
CraigH
If the radiation flux is calculated as:
F = \frac{L}{2*pi*r^{2}} where L is the luminosity of the source and r is the distance from the source
\frac{number-of-scintillations}{time}
What is the relationship between them?
There obviously should be one, as the count rate depends on the distance from the source and the strength of the source, as does the radiation flux.
Is it just a linear relationship? I'm guessing it varies for different scintillators but do they all have a linear relationship, or at least an almost linear relationship?
Thanks!
The number of particles captured in the scintillator will depend on the material and the size of the detector. Together, these and other considerations are encapsulated in the the "efficiency" of the detector. The efficiency is usually assumed to be linear over an appropriate range of particle energies, but there are certainly nonlinearities. For example, this http://www.detectors.saint-gobain.com/uploadedFiles/SGdetectors/Documents/Technical_Information_Notes/Efficiency-Calculations.pdf has graphs for various detectors using different materials. It's clear that there is a decent range where the efficiency is approximately linear, but significant nonlinearities emerge outside these ranges.
Thankyou! This article will be a brilliant reference for my project!
I'm finding it very hard to follow though. Could you please explain a bit more how I would go about finding the expected count rate for a specific detector, (e.g CaF2), when exposed to a certain radiation flux.
e.g if the radiation has a luminosity of 1W and is 1 meter away from the scintillator, What would be the approximate count rate if there is only air between the source a 1 inch CaF2 detector?
Can you tell how I would go about answering this question?
Thanks
The number rate of particles that pass through the detector is the product of the flux and cross-sectional area presented to the radiation source. The efficiency tells you the percentage of particles that pass through that are actually detected. The remainder just pass through without being detected. You should end up with a formula that is the product of flux, area, and efficiency. The actual photon count rate is generally proportional to this, with another factor that depends on the energy of the original ionizing radiation.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
