Relationship between thermodynamics and differential geometry
The discussion highlights the overlap between thermodynamics and differential geometry, particularly through the concept of state spaces and surfaces defined by equations like PV=NkT. The participant is exploring whether this geometric approach to thermodynamics is beneficial and if it has been studied at a basic undergraduate level. They note that existing literature often delves into more advanced topics, leaving a gap for foundational studies. The relationship between thermodynamic phase space and contact manifolds versus symplectic manifolds in classical mechanics is also emphasized. Overall, the inquiry seeks resources that bridge these two fields at an introductory level.
hideelo
I am taking thermodynamics this semester as well as a course in differential geometry of surfaces, and I am seeing a lot of overlap.
For example, I can create a "state space" isomorphic to R3 of TxPxV I can then define a surface on this space of PV=NkT I can define quasi static state equations as curves restricted to the surface.
Is this an approach a useful approach to thermodynamics? Is this studied at all? I Googled "Thermodynamics differential geometry" and got results that were about much more advanced topics in thermodynamics. Is there a text, or paper, studying basic (I am taking an undergrad course) thermodynamics from this perspective?
Science news on Phys.org
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
