Relative and absolute potential?
The discussion centers on the concepts of absolute and relative potential in charged capacitors. It clarifies that while charge is absolute, voltage is a measure of potential difference. The experiment with three 100,000V capacitors in series raises questions about charge distribution and the effects of disconnecting the top capacitor. When disconnected, the top capacitor maintains a 100kV difference between its poles but does not retain the absolute voltage offset compared to the lower capacitor. Ultimately, there is no difference in behavior between the disconnected capacitor and the lower capacitor in terms of voltage potential.
Artlav
Hello.
I've been thinking about potential on charged capacitors, and got confused.
A charge is AFAIK absolute - there is a balance of electrons and protons in matter, which can be biased one way or another.
However, voltage is defined as difference of potential, not an absolute value.
So, 100 volts on the ground is the same as 100V in a middle of a charged thundercloud.
But what kind of charge distribution could there be on a charged capacitor?
The experiment is such:
Take 3 100000V capacitors, and stack them in series.
When charged, top one would have 200kV on one side and 300kV on the other.
These voltages alone are sufficient to produce electric field-related effects, like static cling.
What would happen when that upper capacitor is disconnected from the rest?
Would it maintain the absolute charges - i.e. would there be a 300kV and 200kV worth of static cling?
It would obviously maintain a 100kV difference between the poles, but would the absolute offset remain - that is, is there any difference between it and the lower capacitor in the stack that have 0V and 100kV?
No. There's not.
  • Skeptical
Likes joseph707
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
