Relative length and velocities using Lorentz transformations
The discussion revolves around calculating the relative velocities and time intervals of two spaceships, A and B, using Lorentz transformations. The proper length of each ship is given as 100m, and it takes 1.5 microseconds for the front end of ship B to pass the entire length of ship A according to ship A's clocks. Participants express confusion about applying the Lorentz transformation for velocity addition without knowing the initial velocities of the ships. They seek clarification on how to derive the relative velocity from the provided time and proper lengths, emphasizing the need to understand the lengths in each ship's frame. The conversation highlights the importance of recognizing the proper length and time intervals in different reference frames to solve the problem accurately.
clayton26
Space ships A and B, each having a proper length of 100m, pass each other moving in opposite directions. According to the clocks on ship A, the front end of B takes 1.5 x 10^(-6) s to pass the entire length of A.
a) what is the relative velocity of the two ships?
b) according to clocks on ship B, how long does it take for the front end of A to pass the entire length of ship B?
c) according to clocks on ship B, how much time passes between the time when the front end of A passes the front end of B and the time when the rear end of A passes the front end of B? Does this time interval agree with your answer to B? Should it?
Lorentz matrices.
ATTEMPTS:
So here's what's confusing me: I want to apply the lorentz transformation of velocity addition to find the relative velocity of the spaceships, however I'm not sure how to do that since I don't know their respective velocities to begin with. Is there some way to derive the velocity of one or both of the ships given the time it takes for the front end of ship A to pass through the length of ship B? I wanted to simply take delta(x)/delta(t), but I don't know what to use for delta(x) since the problem only gives me the proper length and no velocity to apply a lorentz contraction. So any help with any part of this problem would be greatly appreciated!
What's the length of ship A in ship A's frame? That's the distance the front end of B travels in the 1.5 μs.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
