Relative velocities - Velocity of impact
Object C and P are initially moving at the same velocity of 8.4 m/s to the right, but when friction increases for object C, it decelerates to a stop over 4 meters. The key calculation involves determining the impact velocity of object P on object C after accounting for the distance between them and their relative acceleration. The initial relative velocity between P and C is zero, and the correct distance for the calculation is 1 meter, not 4 meters. After recalculating, the impact velocity of P on C is found to be 4.2 m/s, which is confirmed as correct. The discussion emphasizes the importance of accurately identifying initial conditions and distances in physics problems.
memoguy
https://dl.dropbox.com/u/51681259/physics_diag.png
Object C & P are moving at the same constant velocity to the right, in the configuration of the image. The friction between object C and the ground is 0. Suddenly the friction increases to μ=0.9 between the ground and object C. This makes object C decelerate to a stop over 4m. At what velocity does object P impact the right internal side of object C. There is no friction between C & P.
d = 1m (distance between p right side and c internal right side)
μ = 0.9
s = 4m (stopping distance)
I can fine object c's initial velocity by combining a couple of formulas:
F_net=ma
F_friction=μmg
v^2=u^2+2as
I find the initial velocity of C & P as being 8.4m/s.
Then I can find the acceleration of C, relative to the ground, after the increase in fiction which turns out to be:
-8.82m/s/s
And that means that relative to C, P accelerates forward at 8.82m/s/s. <IS THAT CORRECT??>
Then I take p's relative acceleration and the initial velocity and put them through v^2=u^2+2as
and find:
v^2=8.4^2+(2*8.82*4)
v=9.39
So my answer is that P impacts C at 9.39 m/s. Is this even close to correct?
<IS THAT CORRECT??>
This looks fine.
Both C and P are never moving faster than 8.4m/s, and they are moving in the same direction. There is no way the impact can occur with more than 8.4m/s.
The calculation has two problems:
- the initial relative velocity between P and C is zero, not 8.4m/s
- the distance is just 1m and not 4m.
Sorry! That was so stupid!
v^2=0^2+(2*8.82*1)
v^2 = 17.64
v=4.2 m/s
Is that correct?
That looks good.
