Relative velocity at a junction
Two cars, A and B, are approaching an intersection at point O, with A traveling at 5 m/s and B at 8 m/s. The time for A to reach O is calculated as 20 seconds, while the distance between the two cars at that moment is 40 meters. The relative velocity of A with respect to B is determined to be 5 m/s at an angle of 36.87 degrees south of east, with the shortest distance between them being 24 meters. The time when they are nearest to each other is found to be 26.4 seconds, but the discussion reveals confusion regarding the time they are equidistant from O, which is resolved to be approximately 33.33 seconds. The ambiguity in the interpretation of distance in relation to the intersection is acknowledged, leading to multiple valid solutions.
Woolyabyss
Two straight roads intersect at point O and cross at an angle Θ to one another, such that tan Θ = 3/4.Two cars, A and B are traveling towards O on these roads,A at 5 m/s and B at 8 m/s
At a certain moment.A is 100 m from the junction and B, on the other road, is 200 m from the junction. Find
(i)the time at which A reaches O
(ii) The distance between A and B at this time.
(iii) The magnitude and direction of the velocity of A with respect to B
(iv) The shortest distance between them.
(v)the time at which they are nearest to one another
(vi)the time when they are equidistant from O
Vab = Va - Vb
I got every part except (vi)
(i) 100/5 = 20 seconds
(ii) 200 - 8(20) = 40m
(iii) Vab = ( -5(4/5)i -5(3/5)j ) -(-8i) = 4i -3j m/s
|Vab| = 5m/s
inverse tan 3/4 = 36.87 degrees south of east
(iv)
40(sinΘ) = 40(3/5) = 24 m = shortest distance
(v)
Pythagoras theorem (40^2 -24^2)^(1/2) = 32m
32/5 =6.4 seconds
20 + 6.4 = 26.4 seconds
(vi)
This is the part I am stuck on.I know I need the distance from O when they are equidistant but I just can't seem to think of any way that I could get none of the examples in my book
covered this any help would be appreciated.
See if you can write an equation for how far A is from O for any time t. Similarly for how far B is from O at any time t.
Alright thanks, I just jotted down this down randomly
5t - 100 = 8t - 200... 3t = 100
t = 33.33 seconds
This is the right answer according to the back of my book but for some reason I feel as though the method I just used isn't the right one since if I picked any time before A passed O I would get a negative distance.
Any thoughts?
Since displacement is a vector quantity would the negative sign just be telling you that its displacement is at the opposite side of O?
OK, you set up equations such that positive positions are interpreted as positions beyond O while negative positions are before reaching O. That's fine.
The question is a little ambiguous. Usually "distance" is interpreted as positive independent of which side of O you're on. You have found a solution for when both cars are past O. Can you find another solution where one car is beyond O while the other has not yet reached O (but they are the same distance from O)?
The question is a little ambiguous. Usually "distance" is interpreted as positive independent of which side of O you're on. You have found a solution for when both cars are past O. Can you find another solution where one car is beyond O while the other had not yet reached O (but they are the same distance from O)?
Would it be 5t -100 = 200 - 8t
t=23.077 seconds
bearing in mind the previous answer I got is the only one that is given as a solution at the back of my book.
Yes. That looks good. I guess the book is ignoring that answer.
Alright thank you.
Alright, thank you.
