mholland
- 7
I've attached a drawing, simplified of the layout of the system I'm working on.
I've figured out a function to give me the length of the beam 'x' for a given angle, easy enough, but i need to know the velocity that the end of the rotating beam moves relative to the lower fixed end, so the rate of change of 'x'.
Now i know that the rotating beams angular velocity is ω=2.289 rad/s and a=1077625 and b=522600 and the length of the rotating beam is 1005mm, and the fixed part is 260mm. ω=2.289 rad/s
Basically, there is a damper attached between the two points and i need to know the velocity it'll be moving at points of its rotation
Any pointers would be great, I'm baffled!
