Relativistic calculation of speed when the momentum is known
The discussion revolves around the relativistic calculation of speed when the momentum of an electron is known. Participants explore the relationship between momentum, mass, and speed, particularly in the context of relativistic effects that prevent speeds from exceeding the speed of light.
  • Participants discuss the transformation of the momentum equation to derive the speed of the electron. There are attempts to manipulate the equation p = mv/√(1 - v^2/c^2) to isolate v, with various algebraic steps presented. Some participants question how to arrive at the final form of the equation v = (p*c) / √(m^2*c^2 + p^2).
The discussion is ongoing, with participants providing algebraic manipulations and suggestions for isolating v. There is no explicit consensus on the most straightforward method, but several lines of reasoning are being explored.
Participants note the importance of units in calculations and the constraints imposed by relativistic physics, particularly regarding the maximum speed limit set by the speed of light.
Karagoz
We know the momentum of an electron, which is: 1,48*10^-21.
Momentum is m*v (mass*speed)
If we divide the momentum by the mass of the electron to find electron's speed, it'll give a value where v> 3*10^8 m/s.
Since speed can't be above speed of light, we have to calculate it relativistic to find the speed of light of the electron.
gives:
With the formula above, the problem is easy to solve.
But I don't get how that formula is transformed.
When I try it, this is what I get:
divide by m, and multiply by √(1 - v^2/c^2)
v = p/m * √(1 - v^2/c^2)
^2 both sides
v^2 = p^2/m^2 * (1 - v^2/c^2) = p^2/m^2 - (p^2*v^2)/(c^2*m^2)
making some changes so both have same divsor:
v^2 = (p^2*c^2)/(m^2*c^2) - (p^2*v^2)/(m^2*c^2)
How do they get the equation where:
v = (p*c) / √(p^2 + m^2*c^2)
Collect together the terms that contain v2 and factor out the v2.
(The toolbar has a superscript tool.)
Start with your first Relevant equation and solve for v! Collect all the terms with v on one side, square everything to get rid of the square root, and solve for v2
Also, remember that numbers are useless without appropriate units.
^2 both sides
making some changes on the right side so both have same divsor:
This was where I left:
Add + (p^2*v^2)/(m^2*c^2) on both sides.
v^2 + (p^2*v^2)/(m^2*c^2) = (p^2*c^2)/(m^2*c^2)
Get a common divisor on left side.
(v^2*m^2*c^2)/(m^2*c^2) + (p^2*v^2)/(m^2*c^2)
Simplify the left side
v^2(m^2*c^2 + p^2) / (m^2*c^2) = (p^2*c^2) / (m^2*c^2)
Multiply both sides by: (m^2*c^2)
v^2(m^2*c^2 + p^2) = (p^2*c^2)
divide by (m^2*c^2 + p^2)
v^2 = (p^2*c^2)/(m^2*c^2 + p^2)
SQROOT both sides:
v = (p*c) / √(p^2 + m^2*c^2)Do you know a more simplified way?
p/m = v / √(1 - v2 / c2)
p2 / m2 = v2 / (1 - v2 / c2) = 1 / (1/v2 - 1/c2)
(1/v2 - 1/c2) = m2 / p2
1/v2 = (m2 / p2) + (1/c2))
That separates the v to the left. Now take the lcm on the right hand side, invert, and take the square root.
  • · Replies 27 ·
