Relativistic form of Newton's second law
andresordonez
SOLVED
(Problem 10, Chapter 2, Modern Physics - Serway)
Recall that the magnetic force on a charge q moving with velocity \vec{v} in a magnetic field \vec{B} is equal to q\vec{v}\times\vec{B}. If a charged particle moves in a circular orbit with a fixed speed v in the presence of a constant magnetic field, use the relativistic form of Newton's second law to show that the frequency of its orbital motion is
<br /> f=\frac{qB}{2\pi m}(1-\frac{v^2}{c^2})^{1/2}<br />
<br /> F=\frac{ma}{(1-v^2/c^2)^{3/2}}<br />
The particle moves in a circle then the magnetic field is perpendicular to the velocity and F=qvB.
<br /> f=\frac{v}{2\pi R}<br />
<br /> qvB=\frac{ma}{(1-v^2/c^2)^{3/2}}<br /> =\frac{m}{(1-v^2/c^2)^{3/2}}\frac{v^2}{R}<br />
<br /> R=\frac{mv}{(1-v^2/c^2)^{3/2}qB}<br />
<br /> f=\frac{(1-v^2/c^2)^{3/2}qB}{2\pi m}<br />
What's wrong?
The relativistic form of Newton's second law is
<br /> \frac{\partial\vec{p}}{\partial t} = \vec{F},<br />
where
<br /> \vec{p} = m\gamma(v)\vec{v}.<br />
The factor
<br /> \gamma(v) = \frac{1}{\sqrt{1-(v/c)^2}}<br />
is constant in this task. Do not differentiate it!
Write the differential equation system for v_x and v_y and derive the frequency.
Good luck!
Thanks!
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
