Relativistic momentum and gamma factor - differential equation
The discussion focuses on deriving the force equations for a relativistic particle under different conditions, specifically when the force is perpendicular and parallel to the particle's velocity. There is confusion regarding the time derivative of the gamma factor, particularly why it is zero in the perpendicular case and the use of v_x instead of v. Participants suggest revisiting the time derivative of the full momentum vector to clarify the relationship. Additionally, there is a challenge in integrating the kinetic energy equation, with hints provided to explore hyperbolic functions for a solution. The conversation emphasizes breaking down complex problems into manageable parts for better understanding.
kapitan90
I am supposed to show that the force on a relativistic particle when
a) it's perpendicular to particle's velocity is F=γm_0\frac{dv}{dt}
b) it's parallel to particle's velocity is F_x=m_0γ^3\frac{dv_x}{dt}
I may make use of the fact that \frac{dγ}{dt}=\frac{v_xγ^3}{c^2}*\frac{dv_x}{dt}
2. Relevant equation
I don't understand why \frac{dγ}{dt}is 0 in case a) (this follows from the last formula, but I don't understand it either), why do we use v_x instead of v which γ depends on ?
I am also supposed to show that the kinetic energy of a particle accelerated from rest to v_xisW =∫F_xdx=m_0c^2(γ-1) but I am stuck with the integral∫ (1-v^2/c^2)^{-0.5} dx I tried to integrate it by parts and to use Wolfram, but it couldn't solve it either. Any ideas?
One problem at a time. First problem
Your formula for d(gamma)/dt is not quite right. Well, it's right for your scenario, but it's also confusing you. Try going over the time derivative again. Maybe first try to take the time derivative of the full momentum vector, and then analyze the two cases when it comes time. Then to predict a future complication, don't be worried if you have a v^2/c^2, you can rewrite as some common terms.
Okay, because I don't know when I'll check back, I'll give you a clue to the second problem, it starts with hyper and ends with trig.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
