Relativity and Black Hole Question
Salamon
Assume that there exist two people, person A and person B. Person B is falling into a black hole.
I understand that due to relativity and time dilation, person A will have to spend an infinite amount of time to watch person B cross the event horizon. Person B will appear to move at a slower and slower rate towards the event horizon. (I know that person B will be gravitationally red shifted).
So is it true, that relative to us in our universe, nothing ever falls into a black hole?
If this is true, how is it possible that black holes ever form in the first place?
There is no requirement in physics that says that if something is not visually seen to happen by a particular observer then it must not have happened. Person A's visual experience has nothing to do with what happens or doesn't happen to B.
Because relative to the black hole, stuff falls in. It doesn't care what things look like from our reference frame.
well, each coordinate system should give a consistent picture, right? So with the Schwarzschild metric, any test particle which starts outside the event horizon will end up at the event horizon at ##t \rightarrow \infty##. So I guess the OP's concern is how matter would end up inside the event horizon to form the black hole.
I don't know much about GR, so I'm not really sure about this kind of stuff. But I would guess that the reason is related to the fact that it is a test particle. And if we consider the 'true' metric due to some spherical mass distribution, then it is possible for that matter to fall inwards to create the black hole. (i.e. to create the situation which is given by the Schwarzschild metric, where all the significant matter ends up inside the event horizon). I mean, when there is significant matter outside the event horizon, then that situation is not really modeled by a Schwarzschild solution, if I understand it right.
For the portions of spacetime that the coordinate systems covers, yes. But there's an entire region of spacetime that isn't covered by the external Schwarzschild solution at all. I can't assign a Schwarzschild ##t## coordinate to a point on the event horizon, but that doesn't mean that a particle cannot follow a worldline to and through the event horizon, it just means that I can't use Schwarzschild coordinates to describe that worldline.
hmm. OK. But in the Schwarzschild coordinate system, it is true that the test particle approaches the event horizon, and gets 'stuck' just outside it, right? You can say this is not the best coordinate system to choose, but that's what happens according to this coordinate system. (unless I've not understood correctly).
No, in the Schwarzschild coordinate system, the test particle asymptotically approaches the horizon as ##t## goes to infinity; it never gets "stuck". But even the asymptotic approach is because the coordinates are singular at the horizon, not because the particle doesn't reach the horizon. The closer you get to the horizon, the more distorted Schwarzschild coordinates are, to the point of infinite distortion at the horizon.
No, this isn't right, because you can't use coordinate-dependent quantities to tell "what happens". You have to look at invariants--things that don't depend on what coordinates you choose. The appropriate invariant here is the proper time along the infalling object's worldline from some large radius to the horizon, and that is finite.
In the idealized case of a perfectly spherically symmetric collapse, the vacuum portion of the spacetime (i.e., outside the collapsing matter) is modeled by a Schwarzschild solution (which contains both a region outside the horizon, and a region inside the horizon, once the collapsing matter falls inside the horizon radius for its mass). The region occupied by the collapsing matter is modeled by a collapsing FRW solution (the time reverse of the sort of solution that's used to model the expanding universe), which is matched to the Schwarzschild solution along the boundary at the surface of the collapsing matter. Oppenheimer and Snyder first developed this idealized solution in a 1939 paper; MTW give a good discussion of it.
I would take the complete opposite approach. I would say that no coordinate system gives the physical "picture". The physics is in the invariants, not the coordinates.
Each coordinate system will calculate the same invariants, but it is those invariants and not the coordinates which are important.
Consider as an analogy a map of the world drawn with the Mercator projection. On such a map you have to travel an infinite distance (on the map) upwards to reach the North Pole. Yet people have traveled to the North Pole, and beyond, covering a finite distance (on the Earth's surface).
Likes Dale
I think it is necessary to include the mass of the infalling person to the mass of the black hole. If you treat the black hole as static, and the person's mass as negligible, then the person never crosses the event horizon in the Schwarzschild metric. But a real person has mass, so the event horizon increases in size when a person falls in, so the static Schwarzschild metric isn't valid.
This is incorrect. Why do you think this?
Technically this is true, but for any black hole of practical interest, i.e., of stellar mass or larger, its mass will be so much larger than the mass of a typical infalling object that the static Schwarzschild metric works fine for analyzing the infall process.
No that's not really what's going on. In general we go from stationary state to stationary state of the black hole i.e. a certain multi-parameter family of stationary black hole solutions and infalling mass perturbations can be taken into account using the equations of black hole dynamics but if the infalling mass is negligible in comparison to the black hole mass then the stationary state solutions are essentially the same.
In the freely falling frame of the radially infalling test particle, there are no "issues": the Schwarzschild metric can perfectly well describe the physics as observed in this freely falling frame and we simply find that the freely falling particle falls past the event horizon in finite time as read by a comoving clock. For static observers there is an infinite redshift of light signals being sent from the infalling particle, simple as that-it's only ostensibly an "issue".
Awesome, thanks. I believe this is the kind of answer the OP (and I) was looking for. I don't have that book, but I found this webpage http://www.aei.mpg.de/~rezzolla/lnotes/mondragone/collapse.pdf Which gives more detail on this kind of stuff (although probably not as much detail as that book gives, but oh well).
So anyway, the Oppenheimer and Snyder solution seems to be a specific case for when the matter distribution is uniform within some region, and zero outside. But that's pretty good. I think that gives a good idea of the sort of behaviour to expect. And as you say, in this case, the region occupied by the collapsing matter is modeled by an FRW metric, not a Schwarzschild metric.
I think this is the key point, because in the FRW metric, the geodesics will fall through the event horizon, to the centre of the mass distribution. So this gives an answer as to how matter can form the black hole in the first place. (Because the metric is not a Schwarzschild metric in the first place). When the matter distribution is spread out, the event horizon is well within the region of matter. Therefore, this matter can pass inwards through the event horizon (which is contained in the region described by FRW metric). And as matter passes inside the event horizon, the event horizon grows, until eventually, the event horizon is greater than the matter region. And it is only now, that the event horizon is in the region described by the Schwarzschild metric.
Also, the region which is described by the Schwarzschild metric is only outside of any non-negligible amount of matter. So, if we have formed a black hole, yet there is more material which is outside the event horizon, then the metric describing the larger region of matter is not a Schwarzschild metric. And this is the reason that the black hole is able to pull the extra material inside the event horizon (even according to some far-away stationary observer).
Just to reiterate the point I'm trying to say here: I agree that we can just use Invariants, or some other coordinate system, and everything will work out fine. What I was trying to figure out is how the Schwarzschild coordinates are reconcilable to what is actually going on. In other words, how it can be reconciled with the fact that matter must be inside the black hole, yet in the Schwarzschild coordinates, geodesics do not pass through the event horizon. And what I think is the reconciling answer, is that the FRW metric is the correct metric, when there is still infalling, non-negligible matter. (And I think this is the kind of answer the OP was looking for). And thanks to PeterDonis, who actually explained this first.
edit: well, the FRW metric is only for a specific case when the infalling matter is homogeneous within some region. For a more general matter distribution, there would be a more general metric. But anyway, the FRW metric is a good example of the kind of metric tensor which would apply to the infalling matter.
I think the best way to try to understand that is to forget about the black hole and study Rindler coordinates instead. Rindler coordinates is a set of coordinates for flat Minkosky space (special relativity) which exhibits a horizon (with hawking radiation and all). It comes to show how nothing special really happens at a horizon. Rindler coordinates are useful for uniformly accelerated motion (constant proper acceleration). It turns out that if you accelerate, part of minkowsky space becomes invisible to you (because it is behind the horizon).
This is not correct. The correct statement is that geodesics reach the "edge" of Schwarzschild coordinates (i.e, the limit as ##t \rightarrow \infty##) in finite proper time, and at that point, Schwarzschild coordinates can't describe what happens. That's not the same as what you said in the quote above; what you said in the quote above would only be valid if Schwarzschild coordinates could actually cover the horizon, and they can't.
Obviously the Schwarzschild metric is not valid when there is non-negligible matter present, since the Schwarzschild solution is a vacuum solution. However, you are wrong in thinking that this means there is anything to "reconcile". See above.
according to a far-away observer, if we used Schwarzschild solution, infalling matter would stop at the event horizon. This is a problem. But Schwarzschild solution is not the correct solution when there is still infalling matter. Therefore, no problem. This is what I would say to the OP. Am I right in saying this? Or do I still have it wrong?
This is wrong. It doesn't stop at the event horizon. The distant static observer simply asymptotically loses communication with it because incoming light signals from it to the distant static observer get asymptotically infinitely redshifted.
No, this is *not* correct. You are mistaking an artifact of coordinates for an actual physical phenomenon.
If the infalling matter is negligible in mass compared to the black hole, the Schwarzschild solution is not *exactly* correct, but it's a very, very good approximation, certainly good enough that if it did in fact predict that matter could not fall through the horizon, that would be a problem. There is no problem because it does *not* predict that.
If the infalling matter is *not* negligible in mass compared to the black hole, then the solution is certainly more complicated, yes. But if such a solution were the only way to describe matter falling into a black hole's horizon, that would be a problem, since there are many cases of interest in which the mass of the infalling matter *is* negligible. There is no problem because, as above, the Schwarzschild solution works fine for such cases.
No, using SC coordinates, you readily calculate that a falling body reaches the end of the coordinates in finite proper time, with all local processes proceeding normally. The coordinates then cannot say anything more. You want to say more, you must use coordinates that cover more. As for 'stopping', using SC coordinates you can compute the relative velocity of an infaller with respect to a near horizon static observer. This speed is not asymptotically zero, it is near light speed instead.
The only 'takes forever' aspect to SC coordinates is that the events described in the paragraph above are given t coordinate values approaching infinity. This infinite value has some physical basis because it corresponds to natural simultaneity surfaces for an observer at infinity. Natural simultaneity reflects two way causal connection - ability to exchange signals. Because signals have increasing difficulty escaping the near horizon, the closer you get to it, normal simultaneity makes these correspond to events approaching infinite time for the distant observer. But even in SC coordinates, this says nothing different about the near horizon physics than any other coordinates.
hmm. but according to a far-away observer using SC coordinates, any matter that falls towards the event horizon would only approach the event horizon, as ##t \rightarrow \infty## So any infalling matter would never reach the event horizon, even if ##t## was really large. yes, the infalling matter would pass through the event horizon within finite proper time. But this isn't important to me (the far-away observer), because in reality, according to me, the matter will never reach the event horizon, even if I wait an arbitrarily long amount of time.
No, as has already been stated you simply lose communication with the particle. Two-way light signaling asymptotically approaches infinite round-trip time. The same exact thing happens in Rindler space-time.
This is not the same thing as the particle "stopping" at the event horizon. In order for the particle to "stop" it would have to have zero relative velocity. Relative velocity is local. You cannot have local static observers at the event horizon.
So you equate reality with ability to communicate? If you uniformly accelerate away from earth, you will find it approaching a Rindler horizon. In exactly the sense in which SC coordinates give t=∞ to an infaller reaching the horizon (at 2pm, on their watch, ordinary world around them), Rindler coordinates would give t=∞ to Earth's approach to 2pm. Would really believe, if you were on this rocket, the Earth froze at 2pm?
This doesn't mean what you are claiming it means. See below.
No, the words "in reality" are not correct, because, once more, coordinates do not tell you what happens "in reality". Only invariants can do that. And there is no invariant that says it takes an infinite amount of time for an object to fall to the horizon.
What ##t \rightarrow \infty## means is that the distant observer has drawn a coordinate grid on spacetime, such that events closer and closer to the horizon on an infalling object's worldline have larger and larger ##t## values. But coordinate grids are abstractions. They don't tell you what's physically "real"; you have to compute invariants to see that.
Did you read DrGreg's earlier post drawing an analogy with Mercator coordinates on Earth? The Mercator "latitude" coordinate of the North Pole is infinite; that means that the Mercator projection draws a coordinate grid on the Earth's surface such that points closer and closer to the North Pole have larger and larger coordinate values, increasing without bound. Does that mean that "in reality" the distance to the North Pole is infinite? No. Does it mean that "in reality, according to an observer at the equator, the distance to the North Pole is infinite" (because Mercator coordinates match up with actual physical distances at the equator)? No. All it means is that you've drawn a coordinate grid that gets more and more distorted as you get closer and closer to the North Pole, so coordinate intervals diverge more and more from actual distances.
Similarly, the Schwarzschild coordinate grid on spacetime gets more and more distorted as you get closer and closer to the horizon, so coordinate intervals diverge more and more from actual physical distances and times. That's why you have to compute invariants to see what the actual physical distances and times are. The fact that, very far away from the horizon, coordinate intervals happen to match up with the distant observer's distances and times doesn't mean those intervals must have the same meaning close to the horizon, any more than the fact that Mercator coordinate intervals match up with actual distances at the equator means they must have the same meaning close to the North Pole.
If you still feel inclined to dispute the above, I strongly suggest stepping back and taking some time to review a good textbook on the subject. MTW, for example, has IIRC a good discussion of the limitations of coordinates. If all you can do is to keep on repeating what I quoted above (which you've repeated several times now in spite of being told repeatedly that it's wrong), then there's no point in continuing this discussion since the response isn't going to change.
I don't really care about the ability to communicate. But I am expecting that each coordinate system is a consistent description of the physical situation. You've given a good example :) thanks. I would say yes, according to me on the rocket, if I keep accelerating with the same proper acceleration, then the Earth will never reach 2pm (according to me, in the rocket). What is wrong with that? I thought this was a standard part of relativity.
You're still on the wrong track. IT's true that infalling matter slightly perturbs the black hole metric, but for a small mass the pertubation is not significant, it's not really the answer, it's just a distraction.
The situation is more like Achilles, the tortise, and Zeno, in Zeno's paradox.
The tortise is like the black hole event horizon, and the question is whether Achilles, the fast runner who starts out behind the tortoise, ever reaches the tortoise (the event horizon).
Every time Achilles halves the distance to his goal, Zeno increments his clock by 1 tick. Zeno, according to Zeno time, sees Achilles get closer and closer to the tortoise, but never sees him reach it.
Zeno concludes (incorrectly) that Achilles never reaches the tortoise, because he can't assign a time at which it happens. He also sees Achilles appear to slow down as he gets closer and closer to the tortoise, like the black hole case.
Meanwhile, Achilles, using his own watch, blows past the tortoise in a finite amount of time by Achilles watch.
In abstract terms, how do we describe this? Achilles wordline intersects the tortoise's worldline. Achilles worldline does not stop at the point where it intercepts the tortoise worldline, it continues on beyond that point. However, Zeno cannot assign a time to this event, because of the timekeeping system he adopted - his coordinate system, as it were. If you regard a coordinate system as a map of space-time, Achilles goes off of Zeno's map. But this is nothing physical, its just that Zeno's map doesn't cover all of space-time.
Likes 1 person
No it is not a standard part of relativity. It is a standard part of crank misinterpretation (I am in no way saying this applies to you).
The 'relative' part of relativity is all about the same observed facts having observer dependent explanations. It is never about the observer determining 'what is real' or even the 'scope of reality'. Those are crank notions. Instead, Einstein often regretted the term 'relativity'; he would have preferred to call it the theory of invariance - emphasizing that the universe doesn't care who observes from where, or what coordinates they use.
I'm trying to think of an observed fact that shows that the time on Earth will really 'freeze' at 2pm (according to me), if I keep accelerating away at constant proper acceleration. It's difficult, but this is the best I've got: OK, suppose the shape of our universe is the 3-torus. The universe is still flat, right, since the 3-torus is just ##R^3## modulo the action of the integer lattice ##Z^3##. Now, if I keep accelerating away from the Earth at constant proper acceleration, then according to me, the Earth will never get past 2pm. But also, since the shape of the universe is the 3-torus, I will eventually come back round, and go past the earth. So this is a definite, observable fact, right? And in principle, I could keep going around the universe, passing the Earth each time, and the people on Earth would never reach 2pm according to me. So, anyway, does this example work? Or did I miss something?
Rindler coordinates don't change topology. No coordinates change topology. The universe is still (for SR) a flat Minkowski 4-space. It is just that for a uniformly accelerating observer, setting up coordinates via any simultaneity convention involving sending and receiving signals, 'most' of the universe is inaccessible to two way signals just because the rocket outraces light from much of the universe (it never reaches c, but light from 'most' of the universe can't catch it in finite time because it is getting ever closer to c relative to the emitter). So, setting up coordinates as we normally do, the Rocket simply cannot cover most of the universe, and assigns infinite time coordinates to what inertial observers consider 'ordinary' events.
The SC coordinate situation is very similar. The origin of the infinite time coordinate is nothing other than the inability to exchange signals with the horizon in finite time. A free fall reference frame using two way signals readily covers the horizon and interior. It really is nothing more than the Mercator analogy Dr. Greg mentioned, or the Zeno coordinates Pervect mentioned. Using a Mercator projection has no bearing on what happens at the North pole. It does not mean, in any plausible sense, that the north pole doesn't exist for you. It just means if you choose to use the Mercator projection, you can't represent the North pole.
Now I have to echo Peter, that this seems to going in circles, with all points made by several people multiple times.
Likes 1 person
  • #31
Which it isn't. And anyway, Rindler coordinates are specific to flat Minkowski spacetime, so you'll need to come up with an example specifically set in flat Minkowski spacetime.
That said, even in a 3-torus universe your example doesn't work. See below.
It has a flat metric, yes, but a different topology from flat Minkowski spacetime. Rindler coordinates don't work the way they do in Minkowski spacetime, and there isn't a Rindler horizon the way there is in Minkowski spacetime. See below.
And when you do, you will see the Earth at a time later than 2 pm. Changing the topology of spacetime changes the physics.
Before even trying to tackle this, you should first understand *why* there is a Rindler horizon in flat Minkowski spacetime for an observer with constant proper acceleration. The first paragraph of PAllen's most recent post gives some very helpful hints.
Likes 1 person
  • #32
In addition, some explicit calculations from an older thread might prove useful: https://www.physicsforums.com/showthread.php?t=730009
Likes 1 person
  • #33
Again, I disagree with that expectation and would take the exact opposite approach. No coordinate system is a description of the physical situation. The physical situation is described by the invariants. Coordinate systems merely serve as a computational tool to help easily calculate the invariants.
Coordinate systems are consistent only in that they all agree on the invariants.
The ability to communicate is an invariant. If you don't care about that, then what invariants are you interested in?
Likes 1 person
  • #34
ah, you're right. my example doesn't work. In Minkowski space, the spaceship with constant proper acceleration can wait for an infinite amount of proper time, yet according to Rindler coordinates, the Earth is still inside the Rindler horizon. But if we have periodic boundary (like a torus), then within a finite amount of proper time, the spaceship will pass outside of the old Rindler horizon, and meet the Earth again. So the Earth has passed outside of what was previously called the 'Rindler horizon'.
I think I'm getting there. And sorry for taking up everyone's time. I know I should really learn all this stuff properly first. So don't feel obligated to reply to me. Only do that if you're enjoying the conversation. OK, so in the Rindler coordinates (in standard Minkowski space), as ##t \rightarrow \infty##, the Earth is still inside the Rindler horizon. Which is (in a certain sense) similar to how test particles falling towards a black hole are still outside of the event horizon even as ##t \rightarrow \infty## in the SC coordinates. But also, the test particle falls through the event horizon in a finite amount of proper time. So this means the SC coordinates are geodesically incomplete at the event horizon, right? It is not possible to follow where the geodesic goes in a finite amount of proper time.
Yeah, I appreciate DrGreg's post. But it's not a perfect analogy, is it? Let's say we have some person traveling along the Earth at constant longitude, at constant 'real' speed towards the north pole, and then he keeps going over the other side. In the Mercator coordinates, yes the Mercator "latitude" coordinate does extend upwards to infinity. But also, the person's Mercator "latitude" speed will diverge to infinity, as he walks upwards.
So I can imagine that looking at this person's movement on the Mercator map, he will be walking upwards slowly to begin with, and as his Mercator "latitude" increases, his speed will diverge, and then I will suddenly see him coming back down from the north pole, on the other side of the Earth (longitudinally). So this person has just traveled over the north pole, which in the Mercator map is represented by a diverging Mercator "latitude" speed, so that an infinite amount of Mercator "latitude" is covered in a finite amount of time. Also, if you tell me a specific time, then I can say the person is at a particular Mercator "latitude". And if the time is larger than the time at which he passes over the north pole, then his Mercator position will be at some position on the other side of the Earth (longitudinally).
Although, there is a problem if you give me the time at which he is exactly on the north pole, since I can't give you a Mercator position that corresponds to this. But I can imagine I close my eyes for a short time interval as he passes over the north pole, then the Mercator coordinates seem to be pretty good. In fact, I could truncate the Mercator map at some large value of the Mercator "longitude". Then, if anything passes through the region I have gotten rid of, with constant 'real' speed, I can calculate where that thing will re-enter the truncated Mercator map. Also, in the limit of a very large value at which I truncate, even if the object has arbitrary 'real' acceleration, the 'real' velocity will tend to a constant over the region I have gotten rid of. (unless the 'real' acceleration tends to infinity in the region I have gotten rid of).
Can we do a similar thing for the Schwarzschild (and Rindler) coordinates? i.e. can we just forget about the Rindler coordinates close to the event horizon. i.e. Remove 'Region A' (as I will call it), which is some spacetime region around the event horizon, which is small enough (in spacetime) that we don't really care about it for our description of what is happening to an infalling test-mass. To be more clear, if we think of 1 space dimension, I am imagining this 'Region A' as being the region between the two lines ##x=t+a## and ##x=t-a##. (where ##x=t## represents the event horizon and ##c=1## of course). And the Rindler observers are hyperbolic curves in the region ##x>t## (i.e. they are hovering outside the event horizon).
Alright, so according to the Rindler observers that stay out of 'Region A', the infalling test-mass will pass into the 'Region A' at some finite Rindler time. And after some finite proper time, the infalling test-mass will pop out of 'Region A', somewhere inside of the event horizon. But inside the event horizon, the Rindler coordinates are not defined, so we can't really follow what happens in Rindler coordinates at that stage. But, we can use Schwarzschild coordinates for the inside of the event horizon. So we can continue to map that test-mass, as it is free-falling inside the event horizon.
Can we do a kind of 'truncation' like we did for the Mercator map? In general relativity, the proper time must vary smoothly along the geodesic of the test-mass, right? So we could say that while the test-mass passes through 'Region A', its proper time does not increase at all, and we can just 'ignore' anything that happens inside of 'Region A'. This is not a very nice way to do it... But as long as the 'Region A' is small enough for the kind of experiment we are doing, the difference between the true proper time of the test-mass and the proper time we have assigned to it will be negligible.
So, I guess there is sort-of a way to do truncation like in the Mercator map. Although it is not as nice, since the truncated Schwarzschild coordinates don't really give exactly the correct proper time for the test-mass once it has fallen inside the event horizon.
I would still say to the OP that (in a certain sense), according to the Schwarzschild coordinates, the test-mass never falls through the event horizon. But now, I would also add something like "but Schwarzschild coordinates do not represent an intuitive coordinate time, so don't take it too seriously." None of the possible coordinate systems for the black-hole spacetime have an intuitive coordinate time.
Also, about the question of how all the matter gets inside the black hole... well I'd still say that this is only possible because the correct metric inside the matter region is a FRW (or some other) metric. And the Schwarzschild metric is only correct outside the matter region. In this way, the matter distribution can collapse to arbitrarily small size in a finite coordinate time. (If I understood correctly). p.s. thanks everyone, for helpful explanations.
  • #35
BruceW:
#4:
#26
Dalespam #33:
Let me give a couple simple examples to try exemplify this idea: [all these guys posting helped me develop a picture for myself.]
Right now you are moving at the speed of light in some distant observers frame. Right?
If you are standing next to a house, you see it as big; as a distant observer I see it as "small'.
Who is 'right', 'what is real', the nearby or the distant observer? What happens when different coordinate systems are used by the near and far observer?
Relativity tells us both observers make accurate observations, both are 'right'. In SR we bring observers together via Lorentz transforms to make what appears to be different measures by distant observers consistent. Distant observers have different lightcones so different access to information. A Local observer's clock alway ticks at the same rate; but observed from a distance in either a different gravitational potential or different relativity velocity, the same clock is observed to change pace!
GR makes predictions based on proper time along worldlines, not coordinate time (whether it's in the Schwarzschild chart or any other chart). [To make observer descriptions consistent in GR you have to bring their worldines together...have them interesect. Then everyboday sees the same thing. Coordinate differents are eliminated and invairent s turn out to be the same.]
For example, in the curved spacetime around a nonrotating black hole, if you use Schwarzschild coordinates the distantly viewed coordinate velocity of light decreases [time slows as discussed already] as you approach the horizon and approaches infinite redshift, whereas if you use Kruskal-Szekeres coordinates, the coordinate speed of light is the same everywhere. [As I understand the historical development of BH interpretations, whether or not a BH horizon was 'real' locally took some years to figure out...David Finklestein was the guy who first did this in the account I read.
Someone posted this source of Schwarzschild coordinate explanations in another discussion: http://casa.colorado.edu/~ajsh/schwp.html
[Seems this source describes 'Eddington Finklestein' coordinates. There are applets which let you play some dynamic games with coordinate systems.]
  • #36
Of course not. It's an analogy, not a mathematical isomorphism. But it is good enough to bring out the fundamental point about the difference between the space-time around a static spherically symmetric mass and the Schwarzschild coordinates that we sometimes use to do calculations on the trajectory of bodies moving in that spacetime.
Consider DrGreg's intrepid explorer again. There's no question about the physical reality of his path up and over the curved top of the earth. I can track his path on a globe, on a Mercator-projected flat map (poor choice, as I'd have to lift my pencil at some point), on a polar-projected flat map, by writing his ##\theta## and ##\phi## coordinates (also known as latitude and longitude) as functions of my proper time, his proper time. I could redefine latitude and longitude so that Hong Kong was at ninety degrees north latitude and the zero meridian passed through Sao Paolo and now a Mercator projection would work just fine. But no matter how I describe his motion, he doesn't know or care. It is what it is, and any difficulties I have plotting it have nothing to do with his journey and everything to do with my choice of how I attach numbers to his position at any time.
  • #37
Not even Painleve-Gullstrand?
  • #38
Right.
I would say *after* a finite amount of proper time (the finite proper time it takes for the geodesic to reach the horizon).
No. It's just a more familiar and easier to understand example of coordinates being highly distorted, so that coordinate intervals are very different from physical distances ("infinitely different" at the North Pole).
You can do this, but it's not quite the same as the Mercator case, because the Schwarzschild coordinate patch that covers the region inside the horizon is disconnected from the patch that covers the region outside the horizon. So the infalling object "reappears" in a *new* coordinate patch that is completely separate from the original one, unlike the Mercator case, where the object passing the North Pole reappears in the same coordinate patch it disappeared from (though in a different part of it).
There is also another weirdness that happens in the Schwarzschild interior coordinate patch (the one that covers the region inside the horizon): the coordinate time ##t## *decreases* as the proper time of the infalling object increases! As the object appears in the patch, just inside the horizon, ##t## starts at a very large positive value (close to ##\infty##, since in this coordinate patch ##t \rightarrow \infty## as you approach the horizon from the inside), and it gets *smaller* as the object falls towards the singularity at ##r = 0##.
Wouldn't it be simpler just to leave out the first sentence? All it does is cause confusion. It's still causing you confusion; see below.
No, this isn't true. There is at least one whose coordinate time is reasonably "intuitive": Painleve coordinates, in which coordinate time is the same as the proper time of an infalling object (more precisely, of an object falling in "from rest at infinity", which is an idealized case but can be precisely defined mathematically).
And the "this is only possible" part would still be wrong. Matter can get inside a black hole even if its mass is negligible, so that the overall metric is the Schwarzschild metric to a very, very good approximation. The matter falling in doesn't have to be an isolated point particle; it could be a very, very thin spherical shell of matter, with mass much, much less than the mass of the hole. You would still analyze its infall using the Schwarzschild metric, not the FRW metric, and the analysis would still show that the shell of matter would collapse to arbitrarily small size in finite proper time, adding its own small mass to the mass of the hole.
  • #39
It may be a better one than you realize. In the analogy, forget about time and consider only distances. The intention is to consider Schwarzschild time analogous Mercator map vertical distance (rather than time taken to travel a distance), and proper time of an infalling particle to be analogous to distance traveled northward on the Earth's surface. It takes an infinite amount of Mercator distance to cover a finite amount of Earth distance, so in terms of Mercator distance you could say that, according to the map, a meridian line "never" reaches the North Pole, even though we know in reality it does.
Note also that if we continue a meridian line through the North Pole, the trajectory reappears on the map with Mercator distance decreasing (just like the Schwarzschild t coordinate decreases inside the event horizon).
By the way, for what it's worth I find Kruskal coordinates the most helpful to analyse spacetime near an event horizon. The relationship between Kruskal and Schwarzschild is very similar to the relationship between Minkowski and Rindler coordinates (in that order). Rindler's book Relativity: Special, General and Cosmological uses a modified version of "Rindler coordinates" that are even more like Schwarzschild coordinates.
  • #40
Just one caveat here: the Mercator coordinate patch that the meridian line reappears in is the same one that it disappeared from (i.e., there is a single connected patch that covers both segments of the meridian line). In the Schwarzschild case, the interior and exterior patches are disconnected.
  • #41
ah, that is a pretty intuitive coordinate system (I just looked it up). With constant time, the metric is 'flat' space, so a constant-time hypersurface is just Euclidean space. And at positions very far from the black hole, the metric is the same as the special relativity metric. Also, at constant position, the time dilation is the same as for Schwarzschild coordinates. Best of all, test masses fall all the way into the centre of the black hole. I like this metric a lot. thanks.
I guess, it would fall through the event horizon in finite proper time (even according to the Schwarzschild metric). But there is no coordinate time associated with this process. If anything, it would be at coordinate time of plus infinity. Since we can't assign spacetime events (smoothly) to the matter which falls through the event horizon, I would not like to say Schwarzschild coordinates can give a true description of what is going on. And, it is a nice coincidence that the Schwarzschild metric is not the correct metric when the infalling matter has a significant mass. We are forced to use a different metric, for example the FRW metric. And using this metric, the matter collapses in finite coordinate time. In the Schwarzschild metric, we would have a problem explaining how the matter got to the middle of the black hole, because new infalling matter would take infinite coordinate time to get to the centre of the black hole.
  • #42
Yes.
No. There is no Schwarzschild coordinate time associated with it (meaning the event of the infalling object being exactly at the horizon). There is a perfectly well-defined, finite coordinate time for it in other charts: the Painleve chart, for example, but also the Eddington-Finkelstein chart and the Kruskal chart. So the correct response to your remark that there is no finite coordinate time for it in the Schwarzschild chart is "so what?"
Wrong. The events associated with the matter being at or below the horizon are perfectly well defined. You just can't assign them coordinates in the exterior Schwarzschild chart. But again, so what? There is no rule that says every event must have finite coordinates in every chart. (For example, the Rindler chart on Minkowski spacetime can't assign finite coordinates to any events outside the "wedge" bounded by the lines ##t = x## and ##t = -x##, to the right of the origin. But that obviously doesn't stop those events from being well-defined.)
(Note, also, that you *can* assign finite coordinates to events inside the horizon using interior Schwarzschild chart; and you can also take limits as the horizon is approached in order to compute invariants, even though Schwarzschild coordinates are singular at the horizon. See further comments below.)
They can if you focus on invariants instead of coordinates. You can use Schwarzschild coordinates to compute all the invariants, including the finite proper time it takes for an infalling object to reach the horizon. (You do that by taking a limit as ##r \rightarrow 2M##, i.e., as the horizon is approached; the limit is perfectly well-defined even though the coordinates themselves are singular at the horizon.) And since there is also an interior Schwarzschild chart, you can compute all invariants inside the horizon using that chart; and you can also verify that all limits taken as you approach the horizon "from the inside" in that chart give the same values as limits taken as you approach the horizon "from the outside" in the exterior chart. So you are simply wrong in saying that Schwarzschild coordinates cannot give a "true description" of what is going on. It may be more cumbersome to do it than it would be in another chart, but it can be done.
Only to describe the interior of the collapsing matter that originally formed the black hole; the region of spacetime outside the collapsing matter, including both outside the horizon and inside the horizon once it forms, are described by the Schwarzschild metric.
But in any case, you are trying to extend this statement to a very different scenario, in which the black hole already exists, with vacuum outside it (and inside it, for that matter--the interior of a black hole is vacuum), but then some other piece of matter comes and falls in. That scenario is *not* described by the FRW metric; it is analyzed using the Schwarzschild metric, at least for the case where the infalling matter has a much smaller mass than the hole and is confined to a small region of space. There are other possible ways for matter to be added to the hole, of course, but the case I've just described is of great practical interest, since it describes many processes we see going on in the universe now, which involve very massive black holes swallowing objects much less massive than themselves. So you are simply wrong in thinking that matter falling into a black hole cannot be described using the Schwarzschild metric; physicists are doing exactly that.
No, we wouldn't. See above. At this point you are simply repeating the same erroneous statements without any new supporting argument.
  • #43
BruceW, I would like to elaborate a little on this comment of mine:
You have mentioned the idea of different coordinate systems being "consistent". Let's examine what you mean by this idea.
First, different coordinate systems may not cover the same regions of the manifold. You can see this easily by considering Rindler coordinates on a flat manifold. Clearly, in whatever sense we would discuss consistency, the consistency of two coordinate charts would only be relevant to the intersection between the two charts. For the Schwarzschild chart this means only the region outside (not including) the EH.
Second, coordinate charts clearly disagree on the coordinates assigned, so that cannot be the correct criteria for consistency. So what makes two charts "consistent"? Here, we are interested in physical consistency. In other words, we want to be able to use both charts to represent the exact same physics. That means that there must be a set of quantities that contain all of the physical information, and that those quantities must be the same in all "consistent" charts. Such quantities are given the name "invariant". Therefore, the thing which makes a coordinate chart consistent with another is simply that you can calculate all the same invariants in either chart (in the region of their intersection).
This is why I said above that it is the invariants which are consistent, not the charts themselves.
Once you understand that, then you can simply talk about the invariants and not worry about particular coordinate charts, except when you are going through the effort to actually compute an invariant.
  • #44
PeterDonis said:
Yes.
*humor alert*
I personally blame the chart. You'd think that people would warn poor , unsuspecting students that the Schwarzschild coordinates were singular, instead of letting them find out the hard ...
Oh, wait, we did warn them. Nevermind!
  • #45
pervect said:
*humor alert*
Yep, there's that Schwarzschild chart again, lording it over all the other charts and claiming to give "real" distances and times. Haven't people caught wise to it yet? :devil:
  • #46
But in any case, you are trying to extend this statement to a very different scenario, in which the black hole already exists, with vacuum outside it (and inside it, for that matter--the interior of a black hole is vacuum), but then some other piece of matter comes and falls in...
let's say I'm not trying to extend the statement. The OP's question was how the black hole can form in the first place. The Schwarzschild metric (for sure) cannot describe such a process in finite coordinate time, because infalling matter only gets to the event horizon in infinite coordinate time. Or maybe you would prefer to simply say that the Schwarzschild metric is for vacuum only, so we don't even need to think about whether it could describe the formation of the black hole, since it is not the correct metric anyway. And conversely, something like the FRW metric is a correct metric, and as it happens, for the FRW metric, the infalling matter can pass through the event horizon in finite coordinate time.
This is all I was saying really. So maybe the bit you disagree with is where I was saying 'suppose we did try to use the Schwarzschild metric to describe significant infalling matter, it does not work.' If I change this to simply 'the Schwarzschild metric is not correct when there is significant infalling matter', then that would be better?
PeterDonis said:
... There are other possible ways for matter to be added to the hole, of course, but the case I've just described is of great practical interest, since it describes many processes we see going on in the universe now, which involve very massive black holes swallowing objects much less massive than themselves. So you are simply wrong in thinking that matter falling into a black hole cannot be described using the Schwarzschild metric; physicists are doing exactly that.
Right. and in this case (where the mass of the infalling matter is negligible compared to the mass of the black hole), the infalling matter only reaches the event horizon (in Schwarzschild coordinates). So the matter is not really added to the hole. But that is not important anyway (to the value of the gravitational field outside the black hole), since the matter has insignificant mass compared to the mass of the black hole.
yeah, I think that is a key point to remember. The key thing that I wasn't thinking about earlier in the thread, is that a coordinate chart only needs to be consistent over the region of spacetime on which it is defined. So as you say, if we have two coordinate charts which are equivalent in their intersection (e.g. Schwarzschild coordinates and Gullstrand-painleve coordinates), the Gullstrand-painleve chart can describe matter falling through the event horizon, but the Schwarzschild chart cannot, since the Schwarzschild chart does not include the event horizon.
So, this automatically tells us that we can't use the Schwarzschild coordinates to tell us how that black hole came to exist. And that is fine, because the Schwarzschild coordinates are not defined over all of the spacetime described by the Gullstrand-painleve chart, so they are not required to give a consistent description of everything that can be described by the Gullstrand-painleve chart.
Also, as it happens, the Gullstrand-painleve chart does not describe the formation of the black hole, since the Gullstrand-painleve chart is also a vacuum solution. But anyway, the point is that the Schwarzschild coordinates certainly could not describe the formation of the black hole, because it does not even cover the event horizon.
edit: I keep saying 'consistent description' and 'described by', I guess what I mean by this is if the coordinate system can smoothly assign points in spacetime to geodesics which represent a certain physical process. For example, if the coordinate system can describe a certain pair of people meeting up to have coffee, then it should be able to assign points smoothly in spacetime which are geodesics corresponding to the motion of the two people as they meet each other.
  • #47
No, that's still not correct. The correct statement is that, to describe the formation of the black hole, you need a spacetime that has two regions: an FRW region containing the collapsing matter, joined to a Schwarzschild region of vacuum surrounding it. Neither one works by itself; you need both. See below.
No, this is wrong. The FRW metric does not contain any event horizon. To describe the horizon and its formation, you need the Schwarzschild portion of the spacetime, even in the case of the intial collapse to form the black hole.
(It's true that Schwarzschild *coordinates* can't be used to fully describe black hole formation; but coordinates are not the same as "metric". See further comments below.)
Still not correct. You keep on using words like "really" when you are talking about coordinate-dependent statements. Tnat's wrong; or at least, it's an abuse of language. When you use words like "really", it should be in reference to invariants, not coordinate-dependent things. The invariant "reality" in this case is that matter reaches and passes the event horizon and enters the black hole. If you insist on talking about Schwarzschild coordinates, the only correct thing you can say is that those coordinates cannot *describe* what happens to the infalling matter once it reaches the horizon. But again, coordinates are not the same as metric; see below.
Don't confuse coordinates with "metric". The term "Schwarzschild metric", at least as I've been using it and as you have implicitly been using it, refers to a geometric object, independent of the coordinates used to describe it. So when I said, above, that you need both the "FRW metric" and the "Schwarzschild metric" to describe the formation of a black hole, I meant that the full geometry of the spacetime in question consists of two "pieces" with different geometric shapes, the FRW shape and the Schwarzschild shape, joined together at a boundary (the surface of the collapsing matter). You need both pieces to describe the process of black hole formation; so the Schwarzschild *metric* is needed to describe how black holes come to exist.
You can't use Schwarzschild *coordinates* to fully describe the process of black hole formation, because those coordinates can't cover the event horizon. But that doesn't mean the *metric* of the vacuum portion of the spacetime isn't Schwarzschild; it just means the Schwarzschild coordinates can't fully describe the Schwarzschild metric.
Wrong; G-P coordinates *can* be used to fully describe the Schwarzschild metric portion of the spacetime I described above. Also, IIRC, G-P coordinates happen to match up very easily at the boundary to the "natural" coordinates to use for the portion of the spacetime occupied by the collapsing matter (I think this is more or less what Oppenheimer and Snyder did in their 1939 paper describing gravitational collapse).
  • #48
I am glad that helped.
That is part of what I meant by "invariants". Whether or not two people meet is an invariant. Also, whether or not their motion is a geodesic is also invariant. So both of the things that you mention are not coordinate statements, they are invariant statements. Of course, there are many more than just those two invariants, but the invariants are the things that are "consistent descriptions" between overlapping coordinate charts.
  • #49
oh, yes, I forgot to say we need the Schwarzschild metric outside the matter region. Although, for the general case of varying density, I guess we can just use one region. But the metric would not be nice and simple.
really? I thought the event horizon forms inside the matter region described by the FRW metric. And as matter falls in through the event horizon, the event horizon gets bigger, until eventually it ends up outside the matter region.
hehe, OK I'll try to talk more about invariants, and less about coordinates in the future.
uh, well, I have just been using metric to mean the same as coordinates up until now. I guess you mean the metric in coordinate-free representation. I'm not so familiar with that. But I can intuitively understand what you mean. it's just the abstract idea of the metric that describes spacetime, when we don't care about what coordinates are being chosen.
yeah, sorry I meant that G-P coordinates can't describe the matter region. I should have explained myself better.
  • #50
This is a fundamental issue - it's hard to overstate its importance.
The metric itself is a coordinate-independent object that describes the geometry of a given space. It may look very different in different coordinate systems, but it's still the same metric, just as "one kilometer north and one kilometer east" is the same vector as "negative one kilometers south and one kilometer east" or "root-two kilometers north-east". This is a basic property of all tensors, including the metric tensor.
Another example: there is only one metric for a flat two-dimensional surface. In cartesian coordinates, its components have the values: ##g_{00}=g_{11}=1## and in polar coordinates they have the values ##g_{00}=1## ##g_{11}=r^2## but they're both describing the exact same flat two dimensional space.
Likewise, there is only solution to the Einstein field equations for the vacuum outside of a static spherically symmetric mass distribution, and that is the Schwarzschild solution described by the Schwarzschild metric. We can write this metric using Schwarzschild coordinates (which, interestingly, are not the coordinates that Schwarzschild himself used in his original paper), PG coordinates, kruskal coordinates, or whatever... But they are all different ways of writing down the same solution to the same differential equation.
