Can Relativity and Gravity Coexist?
granpa
when you factor relativity into the interactions of charged particles you get magnetism. Relativity says that magnetism is required to make the laws governing the interactions invariant.
What about gravity? When you factor relativity into gravitational interactions do you get yet another field?
If you start with Newton's theory of gravity and add relativity, you don't get a theory that predicts what we observe. There is a well known paper by Currie, Jordan & Sudarshan that shows that it's not possible to have a relativistic interaction term in Hamiltonian theory. So it would appear that a proper theory of gravity can't be constructed this way.
General relativity is built on SR so it is already there. GR and SR are kinematic systems. In GR, the sources of gravity don't interact directly with each other, but affect the spacetime, which is the background of the kinematics.
I've got a feeling I've not answered your question, but that's how I see it.
If you start with special relativity and add Newton's law of gravity, it will be very difficult if not impossible to avoid inconsistencies in the theory (because the force propagates with infinite speed).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
