Building a Remote-Controlled Alarm/Siren System: Components & Connections
To build a remote-controlled alarm or siren system, first determine the type of sensor needed, such as for motion or light detection. The sensor can trigger a 433MHz radio transmitter, which connects to a receiver linked to the alarm or siren. Component availability varies by location, with options like Digi-Key, Mouser, and eBay being reliable sources in the USA. It's essential to clarify the specific sensing requirements to guide the component selection. This project requires careful planning and sourcing of the right electronics.
Klutch1
I have no clue on the first thing to start with. I want to make a remote that signals to a siren/alarm.
1) what kind of electronics/components would I need for a sensor.
2) how can I get it to connect to an alarm/siren sound?
3) where can I purchase the components to make this?
depends on what you want to sense ?? you haven't told us
do you want to sense a change in light level ? maybe a motion?
a fluid level?
the sensor, once determined, could be used to trigger a 433MHz radio Transmitter and
the alarm unit connected to and triggered by the receiver
depends on what country you are in ??
for the USA and some countries digikey, mouser and even eBay will source most parts
cheers
Dave
I want to make my own remote control finder and remote key finder
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
