- 10,902
- 3,782
bhobba submitted a new PF Insights post
Renormalisation Made Easy
Continue reading the Original PF Insights Post.
Drakkith said:Wow, that's all renormalization is? Just saying, "Let's not use our theory at absurdly high energies"?
Jimster41 said:Can you explain more why the improper integral over momentum blows up?
stevendaryl said:There are a few things that are a little mysterious about it, still. So if you assume that you understand the low-momentum behavior of a system, but that its high-momentum behavior is unknown, it makes sense not to integrate over all momenta. But why is imposing a cut-off the right way to take into account the unknown high-energy behavior?
stevendaryl said:The second thing that's a little mysterious is the relationship between renormalization and the use of "dressed" propagators. It's been a while since I studied this stuff (a LONG while), but as I remember it, it goes something like this:
bhobba said:You have to read the reference I gave - its simply the result of calculating the equation.
Very briefly if you have a look at the resulting equation you can simplify it to M(K) = iλ + iλ^2*f(K) + 1/2*λ^2 ∫d^4k 1/k^4 (the integral is from -∞ to ∞) where k is the 4 momentum (its done by breaking the integral into two parts - one for very large k and the other for k less than that). That's a tricky integral to do but after a lot of mucking about, is i π^2 ∫ 1/k^2 dk^2 where the integral is from 0 to ∞. This is limit Λ→∞ i π^2 log (Λ^2).
But as far as understanding renormalisation is concerned its not germane to it. You can slog through the detail but it won't illuminate anything.
Thanks
Bill
wabbit said:IMy recollection of that argument is very hazy so I am unsure about it, but does this work (or rather, something similar, presumably after some renormalization of the argument)?
Jimster41 said:And I need to revisit that MERA paper to see if I missed a similar natural, rather than introduced, re-normalization thresholding process they were proposing.
Jimster41 said:So the Wilsonian "solids" lattice (I now have 100 times more context for lattice gauge theory that I did 5 minutes ago) could/would extend up the energy scale, if it turned out to be that space-time was discrete, since that's how it looks at things in the first place.
I have a book on QCD... that I have not started.![]()
atyy said:if the solid model can be extended up the energy scale, that would mean making the lattice spacing finer and finer, corresponding to a continuum.
Jimster41 said:I wouldn't mind having a reference I could dig into that explains more what the energy scale as spatial dimension means. That's not connecting to anything I understand at the moment and it sounds like it could.
Jimster41 said:Very interesting. I look forward to trying to read that one. The discrete scale in-variance part is clear. Love the stack of lattices. Very much what I have been picturing for re-normalization and (way over-simplistically I'm sure) the MERA thing.
Jimster41 said:The last sentence about how that system of lattices obeys the equations of GR. Do you mean the mathematical properties of GR fall out of it (emerges from, or is consistent as a property of such a system of lattices) ? That's what I am assuming that means, rather than, it's just "another place where GR goes like GR goes? In other words the idea is see if one can derive the way GR goes from the fundamental properties of such a system of lattices applied to the dimensions of space, time, energy, mass?
Jimster41 said:Very interesting. I have to say, I have always felt like LQG and the MERA were somehow so similar. This has helped clarify the difference between them. Or at least provide contrast to what was previously a pure fog of confusion.
atyy said:If we go down the energy scale, we average over the lattice. So we go down a bit, we get a coarser lattice. Then we do down again, and we get another even coarser lattice.
bhobba said:For renormalisable theories it would seem you can shift your energy scale (ie exactly where you stop that limit in getting the field or as Atty says your graining) and it makes no difference to the form of your equations.
This is the interesting renormalisation group flow aspect of the issue.
First - yes it only works for renormalisable theories.stevendaryl said:I remember some other characterization of renormalizable/non-renormalizable theories, and I don't see the connection with what you're saying, though. What I've heard some people say is that a renormalizable is characterized by a finite number of measurable parameters; in the case of QED, there is just the electron mass and charge. But (this is my paraphrase of what I've heard--it's not my own conclusion) in a non-renormalizable theory, every new order of perturbation theory gives new parameters whose values must be determined experimentally. Do you have any idea what that means? (Whether or it's true or not, I'm wondering why people would say it)
stevendaryl said:There is yet another aspect of renormalization that I remember dimly, which is the approach of fixing the infinities that arise in the naive approach by introducing counter-terms that cancel the infinities at large momenta. That doesn't seem exactly the same as introducing a cut-off (although it has the same feature of making larger momenta irrelevant).
stevendaryl said:That's interesting, and that answers my question about why, after renormalization, the power series look very much the same as before, except for the replacement of bare constants by renormalized constants. That's a feature of renormalizable theories, but not in general.
bhobba said:First - yes it only works for renormalisable theories.
How non-renormalisable theories are handled - I have that on my to do list.
