Reply quickly, quiz in a few hours, very simple magnetic field question
The discussion revolves around calculating the magnetic force on a wire carrying a current in a magnetic field. The magnetic field is specified as 0.70 x 10^-4 T, directed 75° below the horizontal, while the wire is 8.5 m long and carries a 12 A current directed east. The correct approach to find the force involves using the formula F = Bsin(θ)IL, where θ is the angle between the magnetic field and the current. The confusion arises regarding the angle to use; it is clarified that since the wire is horizontal and the magnetic field is at 75°, the angle to consider is 90°, making sin(90) equal to 1. The final result indicates the force is directed 15° above the horizontal in the northward direction.
WardenOfTheMint
At a certain location, Earth has a magnetic field of 0.70 10-4 T, pointing 75° below the horizontal in a north-south plane. A 8.5 m long straight wire carries a 12 A current.
(a) If the current is directed horizontally toward the east, what are the magnitude and direction of the magnetic force on the wire?
Magnitude
N
Direction
horizontal and directed due west
15° below the horizontal in the southward direction
75° below the horizontal in the southward direction
75° above the horizontal in the northward direction
horizontal and directed due east
(Force) = (BsinΘ)(I)(L)
In English...(magnetic force) = (magnetic field perpendicular to current)(current)(length)
I know the answer, it is...
F = (0.70 10-4 sin 90) (12 ) (8.5) = (7.14 e -3) N
But I don't understand that the ( ' sin 90 ' ) bit. The magnetic field is 75° below the horizontal and the current is directly on the horizontal. So shouldn't it be sin 75°? I don't understand how can I apply the right hand rule 1 to this situation?
I don't understand what the question is asking, is the magnetic field going into the page (if so, then the force being 15° above the horizontal makes sense).
OK,... i hope this be helpful before your quiz!
the point is the B field is North-South but the wire is East-West... so take a paper as your horizon and draw a line on it as your wire in East-West. now take your pencil and push it trough the middle od the line and hold it 75 degree North South... what do you see? the line and the pencil are 90 degree apart! because one is N-S and the wire is E-W... the B field is making 75 with the paper... but who cares! we want to use the angel between the wire and the B field...
so sin(teta)=sin(90)=1
about the direction if F:
keep the same paper...! ;) have your 4 fingers in the direction if current on the wire ... not rotate your hand slowly to be able to close your fingers in the same direction as B field rotating... (which is inside as you said) so your tumb is heading North!...
good luck!
