(repost since typos) Volume of revolution using shell method
Call my name
(EDITED)
1. Use the shell method to find the volume of the solid generated by revolving about the y-axis. x=y^2, x=y+2
2. same as #1, except change y and x for the two equations and revolve about x-axis.
I tried doing 2pi\int_{x=0}^4(x)(\sqrt{x}-x+2)dx but the answer is off for #1.
I tried doing 2pi\int_{y=-1}^4(y)(\sqrt{y}-y+2)dy, well it's wrong.
Is there a problem with how I established the shell height?
the answer for these two questions are supposed to give me 72pi/5.
Hi Call my name! :smile:
(have a pi: π and a square-root: √ and try using the X2 tag just above the Reply box :wink:)
Call my name said:
(EDITED)
Yeees … it's the shell width, isn't it? :wink:
Are you sure that's the question? If you swap everything, isn't the volume the same?:smile:
Yeah, I meant that those two questions' answers are the same.
So is what I have established wrong?
You've used height instead of width
(or you've revolved around the wrong axis).
What do you mean? I'm a newbie so please specify and clarify
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
