Requency for a photon emitted from a hydrogen atom
The frequency of a photon emitted from a hydrogen atom during an electron transition from n=3 to n=1 can be calculated using the Rydberg formula, resulting in a frequency related to the energy difference between these states. The energy of the emitted photon is approximately 5.89 x 10^-34 Joules, which converts to about 3.67 x 10^-21 MeV. For the annihilation of a positron and an electron, the total energy released is calculated using E=mc², yielding approximately 8.2 x 10^-14 Joules. Understanding these calculations is essential for solving the final physics questions. This knowledge is crucial for mastering concepts in quantum mechanics and particle physics.
pak213
I am having some trouble w/ a take home Physics final.
I am down to my last 2 questions:
1) What is the frequency for a photon emitted from a hydrogen atom when an electron makes a transition from an energy state n=3 to n=1? What is the energy of the photon in Joules and MeV?
2) A positron and an electron collide and annihilate each other. Since all of each of masses was converted into energy, how much energy was released in Joules?
All the help/direction you can give would be much appreciated. :smile:
1) The energy of an electron in an atom depends on the energy state he's in. The energy of the fundamental level (n=1) is -13.6 eV. Find the energy of n=3 in your book. You are told the electron jumps from the energy of n=3 to the energy of n = 1. Now according to the principle of conservation of energy, that energy must have gone somewhere: in the photon. The frequency of a photon is related to its energy according to E = h\nu
2) They just want to know the energy associated with the masses of the electron and positron. Use E = mc².
Hi there,
I understand you are having some trouble with your take home Physics final. Don't worry, I am here to help you with your last two questions.
1) The frequency for a photon emitted from a hydrogen atom can be calculated using the formula:
f = R(1/n1^2 - 1/n2^2)
Where R is the Rydberg constant and n1 and n2 are the initial and final energy states respectively. For this question, n1 = 3 and n2 = 1.
Plugging in these values, we get:
f = R(1/1^2 - 1/3^2) = R(1 - 1/9) = R(8/9)
Next, we can calculate the energy of the photon using the formula:
E = hf
Where h is the Planck's constant and f is the frequency calculated above. Substituting the values, we get:
E = (6.626 x 10^-34 J.s)(8/9) = 5.89 x 10^-34 J
To convert this into MeV, we can use the conversion factor 1 MeV = 1.602 x 10^-13 J. So, the energy of the photon in MeV would be:
E = (5.89 x 10^-34 J)(1 MeV/1.602 x 10^-13 J) = 3.67 x 10^-21 MeV
2) When a positron and an electron collide and annihilate each other, all of their mass is converted into energy according to Einstein's famous equation E = mc^2. Since the mass of an electron and positron is equal to 9.11 x 10^-31 kg, the total energy released would be:
E = (9.11 x 10^-31 kg)(3 x 10^8 m/s)^2 = 8.2 x 10^-14 J
I hope this helps you with your final. Good luck!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
