Automotive Requesting Information on Automotive Diffusers & Downforce
The discussion focuses on the challenge of accurately modeling the force center of a diffuser system for a computer game, reflecting aspects of a Formula One car. The user seeks guidance on estimating the x-y-z coordinates that represent the central location of the downforce created by the diffuser. They explain that the positioning of this force affects vehicle handling, with rear axle placement leading to understeering and central placement resulting in oversteering. The user is looking for a simple formula or reasonable assumptions to aid in their modeling efforts. They also suggest that the Autosport forum may provide quicker insights from knowledgeable team members.
Prairie
I’m in a conundrum. I’m trying to reflect the diffuser aspects of a formula one car for a computer game. The game requires that I indicate the x-y-z coordinates which would represent a central location of the force that a diffuser system creates. Now, I’m absolutely not an engineer, so I have no clue where I should be guesstimating that the center of this force should be.
The flat bottom of the car, in conjunction with the rear diffuser, is suppose to create the Bernoulli effect of accelerating the air passing under the car. And resulting in a downforce on the car. But I don’t know where to tell the game where the center of this force is located.
This aspect has a huge effect on how the car handles. If I locate this force closer to the rear axle, I get a lot of understeering (good rear end grip). If locate the force closer to the center of the car, I get oversteer (a loose rear end). And I’d really like to be as accurate as I possibly could be with this thing.
Because I have the cars modeled in a 3d program, I can closely approximate the locations and sizes of the components of this system. If I could employ either a simple formula, or at least some reasonable assumptions, this would be immensely helpful.
Thanks in advance.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
