Resolve all the Tension into horizontal and vertical forces
To resolve the tension in the system, start by analyzing point B, where tensions BC, AB, and the 20 kg mass interact. Establish equations for vertical forces, particularly focusing on BC supporting the 20 kg mass. Next, apply similar analysis at point C, ensuring to account for the angles involved. Finally, analyze the entire system at point D, where the tension must support the total weight of W plus 20 kg. The key is to set up and solve the equations simultaneously while ensuring the system remains in equilibrium.
masterofthewave124
One end of a chord is attached to the ceiling at D and another to the wall at A. Masses of W kg and 20 kg are attached to the cord so that it assumes the shape shown on the right. Find W and the tension in each of AB, BC, and CD.
http://img126.imageshack.us/img126/9884/forces4zx.jpg
stuck on this question...probably due to the lack of information. these are my thoughts so far: do i want to isolate small areas and solve for the values related to them? for example, taking the point B, tensions BC, AB and the 20 kg are attached to this, do i want to start here? using the values solved, can i proceed to points C and D?
A good strategy would be to start writing down equations and gradually solving for the unknowns. You'll need information from analysis of several key points. We can start from point B, where you can write an equation in the y-direction. The segment BC sin30 needs to be able to support 20kg. Try a similar analysis at point C. Lastly, try analyzing the entire system. The segment from D sin60 must support W+20kg.
Add up these equations (i.e. solve them simultaneously).
The main thing is to resolve all the Tension into horizontal and vertical forces. And note that the system is in equilibrium.(No net force in vertical and horizontal direction)
By the way what is the ans for W ? i try to do it for the fun of it. :P
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
