Resonant Frequency of a wine glass
Resonant frequencies can theoretically break various objects, including walls, by applying energy at their specific frequencies. The effectiveness of this process depends on the material's quality factor (Q), which indicates how much energy it can absorb without significant loss. Glass has a high Q, allowing it to vibrate intensely with minimal energy, while materials like plastic do not resonate effectively. In practical scenarios, walls can be damaged if their resonant frequency aligns with external vibrations, such as during earthquakes. Ultimately, while it is possible to break down walls using resonant frequencies, the energy required and the material's properties play crucial roles in the outcome.
Camulodian
Hello,
I have a question on resonant frequencies. Everyone knows the example of breaking a wine glass by singing an extended note at the resonant frequency of that glass. My question is:
Can other objects be "broken" by this same process? For example, is it possible to produce the resonant frequency of a wall at such a high amplitude that it actually breaks the wall down, theoretically?
When you send energy toward something like this at it's resonant frequency
the amplitude of the vibration you set up in the wall is limited by the
rate of energy absorption in the wall. That is, if the wall is "gooey" then
instead of vibrating it hard, you warm it up instead. In order to break it,
you have to make it vibrate hard enough that cracks form. That means directing enough energy at it to overcome whatever it absorbs and still
make it vibrate hard enough to crack.
This concept of losses and how much energy something will absorb is
called Q for quality factor in engineering. A glass has a potentially very high
Q because glass makes an excellent spring (low mechanical losses) so
that a small power can be built into a large intensity in the glass over time.
This trick doesn't work with plastic because plastics make bad springs.
With raw intensity you can break down any wall. But a perfect crystaline
wall could be broken with very small amounts of power like a human voice
if enough energy can be transferred to it over time.
What are typical Q values for walls? I would think that they would most likely not be "gooey". How much energy are we talking about here? Say I wanted to break down the walls of Jericho like in the Bible. Using what we know about resonant frequencies, would it be possible to break down a wall of that size?
Camulodian said:
Hello,
that is very much possible :
http://www.civeng.carleton.ca/Exhibits/Tacoma_Narrows/DSmith/photos.html
The frequence of the waves in the air has to match the eigen frequence of the material out of which the bridge is built.
marlon
It is indeed quite possible. The worst-hit buildings in earthquakes are very often ones which had the misfortune to match a resonant frequency matching the frequency of the quake, for instance.
However, the resonant frequency of an object can be changed by non-elastic deformations - so if you're applying a steady frequency to a wall, you'll only keep producing ever-larger vibrations as long as you haven't done enough damage to make it resonate at a different frequency (or stop oscillating at all in the mode you're exciting).
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
