Respiration pressure problemPlease help
  • Thread starter Thread starter jmandas
    Pressure
In deep-sea diving, the partial pressure of oxygen must match surface levels, requiring adjustments in gas mixtures. To achieve a partial pressure of 150 mmHg at a total pressure of 9.1 atm, calculations show that 2.17% of the air must consist of oxygen. The formula used involves rearranging the partial pressure equation to solve for the fraction of oxygen. Proper unit conversions, such as changing mmHg to atm, are crucial for accurate results. Understanding these principles is essential for safe diving practices.
jmandas
In deep-sea dives the pressure of the air that a diver breathes may be quite large. The mixture of gases breathed is adjusted so that the partial pressure of oxygen is the same as on the surface of the earth. If a person is breathing air with a pressure of 9.1 atm, what % of the molecules in that air should be oxygen in order for the partial pressure(pO2) to be 150 mmHg.
I think I use F=(p1-p2)/R
I know atomspheric pressure is 1.013810E5N/m^2
blood has pO2 of 40 mmHg
Now of this seems to be going together though.
Please help...! Answer should be 2.17%
Well,it's not difficult.Think of Dalton's law.Consider 100 molecules of air which are at the pressure of 9.1 atm.Compute how many O_{2} molecules from that air would creat a pressure of 150 mmHg.
Pay attention to the units.
Daniel.
P.S.1 atm=101,325 Pa (u don't need it,though).
Hi there, it seems like you are trying to calculate the percentage of oxygen molecules in a deep-sea dive where the partial pressure of oxygen needs to be 150 mmHg. To do this, we can use the formula for partial pressure: pO2 = (F * p) / (F + p), where p is the total pressure and F is the fraction of oxygen. We can rearrange this formula to solve for F: F = (pO2 * p) / (p - pO2).
Plugging in the given values, we have p = 9.1 atm, pO2 = 150 mmHg, and converting mmHg to atm, we get pO2 = 0.197 atm. Solving for F, we get F = (0.197 * 9.1) / (9.1 - 0.197) = 2.17%. This means that 2.17% of the molecules in the air should be oxygen for the partial pressure of oxygen to be 150 mmHg in a deep-sea dive.
I hope this helps clarify things for you. Remember, when solving problems involving gases, it's important to use the correct units and formulas. Keep practicing and you'll get the hang of it!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
