Understanding Rest Mass of an Electron in a Crystal
In summary: We are measuring the total energy/mass of the object in its rest frame. The rest mass of an electron inside a crystal is a result of its interactions with the surrounding particles, and it exists with zero velocity relative to an observer because it is confined within the crystal lattice. In summary, the rest mass of an electron in a crystal is a measurement of the total energy/mass of the electron within the crystal lattice.
kur82
Hi all. we know that the rest is the mass of an object within a coordinate system which has zero velocity, but how does it exist for an electron inside a crystal, which we call rest mass of electron, how electron exist with zero velocity.or we mean by zero velocity of electron with respect to an observer?
Try giving an electron a KE of a few eV. Now, try and calculate how much relativistic effects comes into play at such energies. Do you think it makes that much of a difference for a mass that we measure at such energies with the "rest mass"?
Furthermore, inside a solid, the "effective mass" due to the many-body interactions has a greater effect on the "mass" of an electron (or quasi-electron) than the issue of relativistic mass in many cases.
Zz.
Likes 1 person
When regarding mass, it's simpler and better to just regard the whole energy/mass of a bounded system together instead of trying to index them element by element. For example, the mass of a proton (~900MeV/c^2) is not equal to the mass of the three quarks (~2-5MeV/c^2) which compose it, but mostly due to the strong interaction between the quarks.
Practically speaking this is what we do anyways when we put an object onto a scale for measurement.
1. What is the rest mass of an electron?
The rest mass of an electron is a fundamental physical property that describes the amount of matter contained within an electron. It is approximately 9.109 x 10^-31 kilograms.
2. How is the rest mass of an electron measured in a crystal?
The rest mass of an electron can be measured in a crystal using a technique called electron diffraction, where the electrons are scattered off the crystal lattice. The angle at which the electrons are deflected can then be used to calculate the rest mass.
3. Why is it important to understand the rest mass of an electron in a crystal?
Understanding the rest mass of an electron in a crystal is important in various fields of science, such as solid state physics and materials science. It can provide insight into the behavior of electrons in a crystal lattice, which is crucial in understanding the properties and performance of electronic devices.
4. How does the rest mass of an electron change in a crystal compared to its rest mass in free space?
The rest mass of an electron in a crystal remains the same as its rest mass in free space. However, in a crystal, the electrons may experience interactions with the crystal lattice and other electrons, which can affect their effective mass and behavior.
5. Can the rest mass of an electron in a crystal be manipulated or controlled?
Yes, the rest mass of an electron in a crystal can be manipulated or controlled through various methods, such as applying an external electric or magnetic field. This can alter the interactions between the electrons and the crystal lattice, resulting in changes in their effective mass and behavior.
