Resultant time dilation from both gravity and motion
In summary, when a frame is moving in relation to an observer in his rest frame at infinity, and the frame is in a gravitational well, the resultant time dilation is simply the sum of the motional and gravitational dilation.
  • #106
starthaus said:
Oh, but you do. Do you think that a mathematical sleigh of hand fixes your misunderstanding of basics physics? What axis does the Earth rotate about?
I thought we were working with the Schwartzschild geometry, a non-rotating body.
Still, what difference does Earth's rotation axis make for orbits around the Earth? It's not like the Earth exhibits a non-negligible amount of rotational frame-dragging.
  • #107
So, what is [tex]\frac{d\phi}{dt}[/tex] again?
You are making the same mistakes as JesseM, we are talking about the delay experienced by clocks on the Erath surface due to Earth rotation. What do you think I have been trying to explain to you starting with post 6?
This is not what we are talking about.
  • #108
starthaus said:
Thank you for the honest answer. This brings me to a follow-up question. Can you please show how you calculate the value for [tex]w[/tex]?
I'm not sure the context you have in mind. In my original post, the whole point was to calculate w from everything else that was in the same equation. That's probably not what you meant. So what did you mean? (In other words, if you want w in terms of something else, what is the "something else"?)
  • #109
In this thread I am calculating [tex]\frac{d\tau}{dt}[/tex] as a function of coordinate speed [tex]\frac{dr}{dt}[/tex] from the Schwarzschild metric:
[tex]ds^2=(1-r_s/r)(cdt)^2-...[/tex]
So, it would appear that your [tex]w[/tex] is equal to [tex]\frac{dr/dt}{1-r_s/r}[/tex]. I asked this question before in the thread, in post 10, probably it got missed in the tremendous noise. Is this correct? How would you arrive to [tex]w[/tex]'s value in your derivation? You do not appear to use the same approach I am using, this is why I am interested.
  • #110
First of all I had better come clean about a detail that I glossed over. In my derivation in the other thread I referred to w as speed measured in...
DrGreg said:
the locally-Minkowski coordinates of a free-falling and momentarily-at-rest local observer at that event
...whereas in post #8 of this thread I referred to what I am now calling w as...
DrGreg said:
speed relative to a local hovering observer using local proper distance and local proper time
In case somebody complains, I should point out that the two speeds must be the same. As far as relative velocity is concerned, it doesn't matter whether the observer is accelerating or not, the relative velocity (in this sense) will be the same. (Of course you cannot use that argument for other quantities such as acceleration.)
If you want to express w in terms of Schwarzschild coordinates, you could construct "locally-rescaled Schwarzschild coordinates" at the event of interest (that is multiply each coordinate by a constant such that the metric equals the Minkowski metric at that event only) and then w will be the coordinate velocity in those coordinates, which you can then rescale back into Schwarzschild coordinate velocity.
So, for radial motion only (where [itex]\theta[/itex] and [itex]\phi[/itex] are constant and can be ignored), change coordinates to
[tex]T = t \sqrt{1-r_s/r_0}[/tex]
[tex]R = r / \sqrt{1-r_s/r_0}[/tex]​
where r0 is the value of r where you want to make the measurement, so that the metric becomes
[tex]ds^2=c^2\,dT^2-dR^2[/tex]​
at that point only. Then, along the worldline being measured,
[tex]w = \frac{dR}{dT} = \frac{dR/dr}{dT/dt}\cdot \frac{dr}{dt} = \frac{dr/dt}{1-r_s/r_0}[/tex]​
So, yes, you are correct about w in this case.
Note that if you simply want to calculate [itex]dt/d\tau[/itex] in terms of [itex]dr/dt[/itex] you don't really need to involve w at all, you just plug [itex]dr = (dr/dt)\,dt[/itex] into the metric and it all falls out.
  • #111
DrGreg said:
First of all I had better come clean about a detail that I glossed over. In my derivation in the other thread I referred to w as speed measured in... ...whereas in post #8 of this thread I referred to what I am now calling w as...In case somebody complains, I should point out that the two speeds must be the same. As far as relative velocity is concerned, it doesn't matter whether the observer is accelerating or not, the relative velocity (in this sense) will be the same. (Of course you cannot use that argument for other quantities such as acceleration.)
So, R and T are simply r and t rescaled to make [tex]1-r_s/r[/tex] "go away" from the Schwrazschild metric. I am having trouble assigning any physical properties to R and T and, consequently to w. To me, they are just rescaled versions of [tex]r,t,dr/dt[/tex].
Thank you
My "w" simply falls out the metric (see post 6).
Yes, our methods are identical, I am just skipping the coordinate rescaling step.
  • #112
kev said:
The proper time of a moving clock at r relative to the reference clock at infinity in Schwarzschild coordinates is (using your notation):
[tex] \text{d}\tau = \text{d}t \sqrt{1-r_s/r} \sqrt{1- (1-r_s/r)^{-2}(\text{d}r/c\text{d}t)^2 - (1-r_s/r)^{-1}(r \text{d}\Omega/c\text{d}t)^2 }[/tex]
starthaus said:
OK.
kev said:
The proper time of an observers clock [itex]d\tau_0[/itex] relative to the reference clock at infinity with motion [itex]dr_o/dt_o[/itex] and [itex]d\Omega_o/dt_o[/itex] at radius [itex]r_o[/itex], is given by:
[tex] \text{d}\tau_o = \text{d}t \sqrt{1-r_s/r_o} \sqrt{1- (1-r_s/r_o)^{-2}(\text{d}r_o/c\text{d}t_0)^2 - (1-r_s/r_o)^{-1}(r \text{d}\Omega_o/c\text{d}t_o)^2 }[/tex]
starthaus said:
This is wrong. Since you are putting in results by hand again, try deriving it from the basics and you'll find out why.
OK, there is a typo in the second equation where I missed the "o" subscript for r in the Omega term. I think it is obvious what was intended from the method.
The second equation should be:
[tex] \text{d}\tau_o = \text{d}t \sqrt{1-r_s/r_o} \sqrt{1- (1-r_s/r_o)^{-2}(\text{d}r_o/c\text{d}t_0)^2 - (1-r_s/r_o)^{-1}(r_o \text{d}\Omega_o/c\text{d}t_o)^2 }[/tex]
espen180 said:
... Unless I made an error underway (which is very possible, this was a messy calculation), obervers S and S' don't seem to agree on the value of [tex]\frac{\text{d}\tau_2}{\text{d}\tau_1}[/tex].
I will check it out. :wink:
  • #113
Still wrong, still put in by hand.
  • #114
If the first equation is right, how can the second equation be wrong?
All I have done is change the names of the variables.
  • #115
You did more than that. Look it over carefully.
  • #116
Ah, guessing games again. It was not my intention to do more than changing the names of the variables, so if that is not the case you must be talking about a typo I can not spot.
  • #117
JesseM said:
That would only be the angular speed of a circle that happened to coincide with the equator (which would actually be [tex]\theta = \pi/2[/tex] rather than [tex]\theta = 0[/tex] as I incorrectly stated earlier).
starthaus said:
Yes, so what?
"So what" is that since [tex]\theta = \pi/2[/tex] is the only case of the equation below (from my post 76, and basically the same as your own equation) that actually corresponds to a circular orbit rather than a non-orbiting circular path:
[tex]d\tau /dt = \sqrt{1 - r_s/r}\sqrt{1 - (r sin(\theta) \omega/ c\sqrt{1-r_s/r})^2}[/tex]
...then for a circular orbit with [tex]d\theta = 0[/tex] it must be true that [tex]sin(\theta) = 1[/tex] and therefore the equation reduces to:
[tex]d\tau /dt = \sqrt{1 - r_s/r}\sqrt{1 - (r \omega/ c\sqrt{1-r_s/r})^2}[/tex]
If you then make the substitution [tex]v = r \omega / \sqrt{1 - r_s/r}[/tex], which was exactly the substitution kev made in post #8 (he defined [tex]u = r \left(\frac{d\phi}{dt}\right)[/tex], equivalent to [tex]u = r\omega[/tex], and then he defined [tex]u = v \sqrt{1-\frac{r_s}{r}}[/tex], equivalent to [tex]v = r\omega / \sqrt{1 - r_s/r}[/tex]), then this equation becomes:
[tex]d\tau /dt = \sqrt{1 - r_s/r}\sqrt{1 - v^2/c^2}[/tex]
So the equation is correct for the special case of a circular orbit where [tex]d\theta = 0[/tex]. Do you disagree? If not, then the symmetry argument I already mentioned shows why this would hold for any circular orbit, even one where [tex]d\theta[/tex] was not equal to 0 in our original coordinate system (since you could always rotate into a new coordinate system where [tex]d\theta[/tex] was equal to 0 on the orbit, and the metric would be exactly the same in this new coordinate system since the Schwarzschild metric is invariant under rotations)
Actually now that I've looked back at kev's post #8 more carefully I have no idea why in post 28 you criticized him by saying:
You need to make
[tex]d\theta=dr=0[/tex]
-v is equal to:
[tex]r\frac{d\phi}{dt}[/tex] and not [tex]r\frac{d\theta}{dt}[/tex]
...since it appears to me he did make [tex]d\theta = 0[/tex], and he did define the velocity in terms of [tex]\frac{d\phi}{dt}[/tex] rather than [tex]\frac{d\theta}{dt}[/tex]! I guess I shouldn't have taken your word for it that he did it differently there (even though you could still get exactly the same final result by assuming a circular orbit where [tex]d\phi = 0[/tex] along a short segment, do you disagree? If you do disagree, I can demonstrate)
JesseM said:
Do you disagree that any great circle on a sphere would correspond to a valid circular orbit, including a circle which could be divided into two halves of constant longitude (i.e. constant [tex]\phi[/tex]), or plenty of circles where neither longitude nor latitude were constant?
starthaus said:
The point is that it doesn't.
The point is that what doesn't? You didn't answer my question about whether you disagree that there are valid circular orbits in Schwarzschild spacetime which, in a given coordinate system, would have a description like the one above. If you do disagree then I think you need to do some thinking about how spherical coordinates work, in particular what the coordinate description would look like for an "upright" circle whose plane was at a right angle to the "horizontal" [tex]\theta = \pi/2[/tex] plane.
starthaus said:
The domain for [tex]\theta[/tex] is [tex][0,\pi][/tex]. Do you dispute that?
No, of course not, why do you imagine I would? In post #56 I gave the example of a complete circle where the coordinate description would be such that one half of the circle would have a constant r=R and [tex]\phi = \pi/2[/tex] while the other half would have constant r=R and [tex]\phi = -\pi/2[/tex], I thought it was fairly obvious that the points covered by each half would then be defined by varying [tex]\theta[/tex] from 0 to [tex]\pi[/tex]. Again, do you disagree that this would be a valid coordinate description for the set of points on a single continuous circle, one whose center is at r=0 and whose plane is at a right angle to the [tex]\theta = \pi/2[/tex] plane, and where [tex]d\phi = 0[/tex] along any infinitesimal segment of this circle? If not you should see why, despite the fact that kev actually made [tex]d\theta = 0[/tex] rather than [tex]d\phi = 0[/tex], it would have been perfectly valid for him to do the reverse, either way there'd be a valid circular orbit meeting this condition, there'd be nothing non-rigorous or "hack"-y about such a starting assumption.
  • #118
starthaus said:
Who's talking about free-fall orbits? How many times do I need to tell you that the solution evolved from answering Dmitry67's question about the rate of ticking clocks a different latitudes?
Yes, I understand that's the question you were addressing in post #6, and (minor algebra errors aside) I don't dispute that your answer there is a good one to Dmitry67's post. But this whole debate got started when you disputed my answer to espen108's OP in post #3, in which I cited kev's result; you seem insistent that this is wrong somehow, although you seem to constantly change your mind about why it is wrong. kev's result is valid for all circular orbits, and it's relevant to espen108's OP because in that case the answer is a product of two equations that look just like GR time dilation and SR time dilation.
starthaus said:
What do you think the different [tex]\theta[/tex]'s in the formula represent?
In your formula, you are assuming two circular paths which each have a different constant [tex]\theta[/tex] coordinate. This makes sense as a response to Dmitry67's question about clocks at different latitudes.
starthaus said:
Could you please answer all my questions, in one post and without turning every point into your question?
I reply to posts individually, so if you write one big post I'll respond with one big post, if you write a lot of little posts I'll have an equal number of responses. Up until recently we were going back and forth with big posts, but then for some reason you decided to start breaking up your responses (your posts 77, 80, 84 all respond to my post 76, while your posts 85 and 87 respond to my post 82) which resulted in our back-and-forth being spread out over many more posts.
  • #119
starthaus said:
Yes, obviously. pervect not only truncated the metric, he also got the [tex]g_{tt}[/tex] wrong. Do you disagree?
He made a minor error with [tex]g_{tt}[/tex] which kev corrected in his response, but other than that I still don't know what you mean by "truncated", in his post he started from the abstract form of the metric which included all the terms:
[tex]c^2 d\tau^2 = g_{tt} dt^2 + g_{rr} dr^2 + g_{\theta\theta} d\theta^2 + g_{\phi\phi} d\phi^2[/tex]
Are you calling this "truncated" just because he didn't actually write out the equations for each "g"? There's nothing non-rigorous about this, anyone can look up what they'd all be in the Schwarzschild metric. Or do you think there was something wrong with pervect's next step of specifying that he was talking about a circular orbit where [tex]dr/dt[/tex] and [tex]d\theta/dt[/tex] would be zero, and eliminating the appropriate terms given these conditions?
JesseM said:
A person who doesn't understand something will sometimes also fail to understand that they don't understand it. It's pretty clear that you didn't understand what I was saying if you thought that changing the metric equation by switching the roles of and had anything to do with what I was talking about, since I said very clearly
starthaus said:
You may not realize but what you are talking about is not a rotation of coordinates. What you are talking about is exchanging the rotational motion in the plane [tex]\theta=constant[/tex] with a pseudo-rotation in the plane [tex]\phi=constant[/tex] while all along refusing to admit that you can't complete such a motion since [tex]\theta<\pi[/tex].
(Basically you are trying to convey the idea that a half circle is a full circle. )
Since nothing I said faintly resembles what you are saying, you need to actually explain where you got the idea that this is "what I am talking about", rather than just asserting it. I take it you think something I said implies this somehow? If so, what specific quote? Do you deny that in spherical coordinates, it is possible to find a valid continuous circle whose center is at r=0 and whose coordinates match the description I gave at the end of post 117? If you don't deny that, are you denying that it would be possible to rotate the original coordinate system into a new coordinate system where the same complete circle would now lie entirely in the [tex]\theta = \pi / 2[/tex] plane? If you deny either of these I suggest the problem lies with your understanding of how spherical coordinates work.
JesseM said:
When you keep repeating the same mistaken ideas about what I'm saying even though my words clearly show otherwise, I'm going to highlight the fact that you're not understanding me, if that seems like "talking down", well, better that than being over-polite and allowing you to persist in your mistaken understanding.
starthaus said:
Goes both ways, I think that you refuse to understand something very basic and that you put up this strwaman in order not to admit that the solution you have been defending is incorrect and incomplete. We will not get any resolution on this item so I propose that we table this subject. OK?
Sure, I was only responding to your complaint about "talking down".
JesseM said:
You asked a bunch of questions over a series of posts less than half an hour old and it's obvious I'm in the process of answering them, so hold your horses please.
starthaus said:
I'll wait. Please do not ask any more questions before answering all my questions. I would really appreciate that.
I believe I've now responded to all your replies to me, but I can't agree to the request not to ask any further questions, as that would make it impossible for me to pin you down on a lot of your ambiguous arguments (like the one above where you tell me 'what I am saying' when your summary bears no resemblance to what I actually said and you don't explain how you think it was implied by what I said).
  • #120
Let's start with this equation for the time dilation ratio:
[tex] \frac{{d}\tau}{{d}t}= \sqrt{1-r_s/r} \sqrt{1- \left (\frac{dr/dt}{c(1-r_s/r)} \right)^2 - \left (\frac{r d\theta/dt}{c \sqrt{1-r_s/r} } \right)^2 - \left(\frac{r\sin\theta d\phi/dt}{c\sqrt{1-r_s/r}} \right)^2 }[/tex]
The above equation is obtained directly from the Schwarzschild metric and I think we are all in agreement about its validity.
Now define local velocities [itex] u_x, u_y, u_z [/itex] as measured by a stationary observer at r using his proper length (dr') and proper time (dt'):
[tex]u_x = dr'/dt' = \frac{dr/dt}{(1-r_s/r)} [/tex]
[tex]u_y = r d\theta/dt' = \frac{r d\theta/dt}{\sqrt{1-r_s/r} } [/tex]
[tex]u_z = r \sin\theta d\phi/dt' = \frac{r \sin \theta d\phi/dt}{\sqrt{1-r_s/r} } [/tex]
Substitute these local velocities into the time dilation equation:
[tex] d\tau/dt = \sqrt{1-r_s/r} \sqrt{1- u_x^2/c^2 - u_y^2/c^2 - u_y^2/c^2 }[/tex]
Now define the local 3 velocity as:
[tex]w = \sqrt{ u_x^2 + u_y^2 + u_y^2 }[/tex]
and substitute this value in:
[tex] d\tau/dt = \sqrt{1-r_s/r} \sqrt{1- w^2/c^2 }[/tex]
This is the result obtained in more detail and more rigorously by DrGreg in #8 and valid for all vertical/horizontal or radial/orbital motion of a test particle at r, just as DrGreg claimed.
I do not think there is anything Starthaus can dispute there.
  • #121
Much better, how did you manage to get the winning combination after all the false starts?
All you needed to do is to start from the correct Schwarzschild metric and to factor out [tex]1-r_s/r[/tex]
  • #122
No, we are not talking about clocks on Earth's surface. You were talking about that in response to Dmitry67's post, not the OP by espen180 (you claim Dmitry67's post was originally on this thread and that it was later split, but I'm not even sure you're correct about that--given that you seemed to think Dmitry67's post was always the first one, it's quite possible the two threads were always separate and that you simply got confused and posted on this thread thinking you were still looking at the other thread, I don't remember Dmitry67's post ever being on this thread). The whole debate between you vs. everyone else got started because you claimed there was something dreadfully wrong with kev's derivation, which was meant to deal with the question of time dilation experienced by clocks in arbitrary circular orbits. The set of all valid circular orbits in Schwarzschild spacetime would include orbits with many different orbital planes, just like Pluto and Earth have different orbital planes despite orbiting the same Sun--some of these orbits would be ones where [tex]d\theta[/tex] is equal to 0 (orbits in the [tex]\theta = \pi/2[/tex] plane), but others would be ones in a different plane where [tex]d\theta[/tex] is not equal to 0. Do you disagree?
  • #123
Yes, look at the post above , kev finally got the right formula after a lot of false starts. Feel free to peruse all his false starts throughout this thread (posts 97, 112, etc). I am done.
  • #124
starthaus said:
Yes, look at the post above , kev finally got the right formula after a lot of false starts. Feel free to peruse all his false starts throughout this thread. I am done.
I haven't been following the more recent posts between you and kev on this thread so I don't know if there were any "false starts" in his last few equations, but the original derivation I linked to was fine, and I pointed out in post 117 you could get the exactly the same formula from the equation you were using in post 6. If you want to use some minor error in a recent post by him as an excuse to avoid addressing all the flaws and confusions in your own arguments (in particular your own confused criticisms of my posts, not kev's), be my guest.
  • #125
How about you tell us why instead? Or is this thread destined to exceed 300 posts, too?
Many readers miss out on opportunities to learn due to their understandable unwillingness to sort through 300+ posts of confrontational nonsense that could be avoided by you doing everyone a huge favor by just specifying what you object to and explaining why.
Just try it for once. You might even enjoy being helpful.
  • #126
These are basic math errors, if you can't see them all by yourself, you should find a different hobby. This does not include your current one :trolling.
Enough said that kev understood his errors.
  • #127
If kev made any "basic math errors" in his recent posts to you they are apparently minor ones which don't affect the final equation he derived for circular orbits, as I showed you in post 117 using your own equation to derive it. And of course you have made plenty of minor math errors yourself, like not including the factor of c in post #6.
But never mind, you found a trivial error in someone else's argument, therefore you win the thread! Hooray! (claps very slowly)
  • #128
You keep accusing me of trolling, but you are the one who keeps destroying threads, making them completely worthless for most readers, with your shenanigans.
Back to the point, I'll take that as a NO, you either can't or won't explain (in any rational way) your claims.
  • #129
I help people that are sincere, I don't help trolls. You contributted noothing to this thread.
If you can't spot the errors, you have no business (other than trolling) in this thread. But, I'll give you a hint, the errors have to do with the wrong variables in the expression.Compare against the correct final expression.
  • #130
LOL. Yep, that's why you can't substantiate your claims: because if I can't "spot the errors" I have "no business in this thread".
Is that also why you're so rude and condescending?
Seriously, dude, it might feel good to say something constructive and useful in your posts.
  • #131
Finally. You understand.
Standard response to your trolling <shrug>
So, you are unable to see the wrong variables. ...
I did, I put up quite a few solutions but you can only see the stuff that makes you tick, err troll.
  • #132
LOL. I was responding to your last post which contained nothing useful or constructive.
  • #133
Try reading the other posts, the ones that contain formulas. Can you read formulas?
  • #134
I read them. They weren't the ones I was referring to. Was that not obvious? Can you read English?
  • #135
Since we are at the point in this thread where people are no longer discussing the topic, but rather who is a troll and who isn't, I take it that the topic is no longer interesting. So this thread is done.
Note that if you think someone is trolling, DO NOT FEED THE TROLL!. Please use the REPORT button and report the post/thread to the Mentors.
Zz.
