Finding Velocity as a Function of Time for a Particle with Retarding Force
  • Thread starter Thread starter lapo3399
    Force Particle
The discussion centers on finding the velocity of a particle under a retarding force proportional to the square root of its instantaneous velocity. The initial approach involves setting up the equation m(dv/dt) = -k*sqrt(v) and recognizing it as a separable differential equation. Participants clarify that the integration should be performed separately for v and t, leading to the integral of v^-1/2 on the left side. The correct integration yields v = sqrt[-2kt/m + c], where the constant c relates to the initial velocity v0. The conversation emphasizes the importance of correctly handling the integration process to derive the velocity function over time.
lapo3399
A retarding force acts on a particle with mass m and initial velocity v0 moving on a horizontal surface; this force is proportional to the square root of the instantaneous velocity of the particle:
Fr = -k*sqrt(v)
Find an expression for the velocity of the rock as a function of time.2. The attempt at a solution
I believe that this has to be solved through the integration of the force expression, possibly setting the right side equal to ma or m(dv/dt):
m*dv/dt = -k*sqrt(v)
dv/dt = -(k/m)*sqrt(v)
I don't know how to go about integrating this though, especially considering the v is present on both sides. I tried and this is the answer I got, though I doubt that it is correct:
v = (-3kt/m)^2 + vo
Thanks for any help!
Where does the 3 come from? Could you show your integration please?
Now that I think about it I think it should be done this way (though I'm not sure of this either because it ends with the square root of -kt/m... so unless k is negative it's not real):
v = -(k/m)*int[sqrt(v)]dt
v = -(k/m)*[t*sqrt(v)*(1/v)]
v = -(k/m)*(t/v)
v^2 = -kt/m
v = sqrt(-kt/m) + v0
No, that's not correct. You have a v on the right hand side, so cannot simply integrate the left hand side to give v. This is a separable equation: \frac{dv}{\sqrt{v}}=-\frac{k}{m}dt. Can you solve this?
So you would integrate both sides with respect to t? If that is the case, I know that the right side will be -kt/m, but I do not understand how to perform the left side's integral.
Oh. You integrate the left side with respect to v and the right with respect to t? So
int[v^-1/2]dv=-kt/m + c
1/2v^1/2= -kt/m + c
v=sqrt[-2kt/m+c]
Would c somehow have to do with v0 then? Would it be
v=sqrt[-2kt/m] + v0 ?
