How can reversing current affect battery charging?
Reversing the current direction while charging a battery can lead to complications, as only the correct direction charges the battery effectively. In certain cases, such as with capacitors, charging can occur in either direction, but this is not true for all battery types, particularly chemical batteries. Using a diode rectifier is essential to prevent reverse current from draining the battery instead of charging it. Connecting a charger incorrectly can cause harmful chemical reactions within the battery, potentially leading to damage. Dedicated chargers are designed to ensure correct polarity to avoid these issues.
spidey
i am connecting a wire to a battery and i pass current in wire and so battery will be charged.suppose if i change the direction of current then will the battery charge? i.e if i change the direction of current alternatively after some time?
why i am confused is because of this? suppose if i move magnet through a coil connected to battery then an emf will be generated and is stored in battery.then if i move the magnet away i.e in opposite direction then the direction of current is reversed so now will the battery charge?
When you hook up a circuit to a battery to power a light for instance, current will flow until the battery is drained. Reversing the direction of the current through the battery using an external power source will charge the battery. This direction is the ONLY direction that charges the battery.
I would say it depends on the battery type. A capacitor, electrolytic for example, can be charged in either direction. A car battery or chemical battery structure may be different.
This is a good question, if you think about one of those cheap, shake up flash lights - they have a coil and then a metal slug in them, so the slug goes through the coil and this produces energy that gets stored in the battery. If it goes the other way though, you just drained that battery. My guess is that they have a diode built into them and that you only get power in one direction.
Guys, you use a diode rectifier to couple the AC from a coil into a battery to form the charging circuit. The diode also keeps the charging circuit from being a load to the battery.
how can we aviod reverse current charging
You have to be careful to avoid this.
If you connected a battery charger the wrong way around to a car battery that was already flat, you could attempt to charge the battery the wrong way around and it would possibly harm the battery by causing unwanted chemical reactions in the battery.
Although the battery charger contains diodes, they would be conducting normally in this case, but still doing damage to the battery.
This is why dedicated battery chargers, like those used on laptop computers for example, always have a plug that can only be connected the right way around.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
