Reversible Processes Explained: Entropy, Time, & More
In summary, a reversible process is a process that occurs against a very small amount of opposing force. This opposing force is necessary to prevent entropy from being generated. The process must take place over a long period of time in order to avoid generating entropy.
Silviu
624
Can someone explain to me what a reversible process means, because I am not sure I really understand. Intuitively it should be a process that should work both ways, but I am not sure I understand how it is related to entropy (the change of entropy should be 0, but I am not sure I understand which entropy: system, surroundings, both?). And I am not sure I understand why does it take an infinite amount of time. Thank you!
You may think of a reversible process as one that is occurring against a very small amount of opposing force. I'm assuming you're referring to a reversible process in regards to thermodynamics, so a reversible process would be a process where your system and surroundings can be brought back to their initial state. By the way entropy change is not 0 for a reversible process, it is so for a reversible,adiabatic process as dQrev is 0 in this case. Remember that entropy in not a conserved quantity, in reality it is always changing.
In classical mechanics a solution ##x(t)## of equations of motion is reversible if ##x(c -t) ## is also a solution to equations of motion ##\forall c\in\mathbb{R}##.
It might be more precise to say a very small difference in the amount of opposing force, or, better still, a nearly equal opposing force. Zero opposing force would maximize reversibility because it would maximize the gradient driving the reaction.
Moran et al, in Fundamentals of Engineering Thermodynamics, discuss what they call Internally Reversible Processes and Overall Reversible Processes.
Internally Reversible Process: In an internally reversible process, a system is made to pass through a continuous sequence of thermodynamic equilibrium states. This is accomplished by doing work on the system boundary very slowly and transferring heat to the system at its boundary very slowly. So, at each point of the process, the system is only slightly removed from being at thermodynamic equilibrium. The main factors causing entropy to be generated in an irreversible process are viscous dissipation of mechanical energy resulting from rapid deformation, and rapid conductive heat transfer within the system resulting from large temperature gradients. In an internally reversible process, these sources of entropy generation are excluded from occurring. The slowness of the heat transfer and of the work cause the internally reversible process to take place over a long period of time. The reversible path that the system experiences in an internally reversible process can be the exact same path that it experiences in an Overall Reversible Process. However, even if the system is experiencing an internally reversible process path, this does not necessarily mean that the surroundings are also experiencing an internally reversible process path. For example, if we use our arm to cause a gas to be compressed within a cylinder along an internally reversible path for the gas (our arm is the surroundings), our arm will certainly not undergo a reversible path. There are all sorts of irreversible processes occurring within our muscles that prevent this. So the surroundings may not be experiencing an internally reversible path of their own.
Overall Reversible Process:
In an Overall Reversible Process, both the system and the surroundings are experiencing (complementary) internally reversible processes. In this case, the entropy change for the system plus the entropy change for the surroundings is equal to zero. In order to achieve this, we must make sure that the surroundings are handled very carefully. For example, if the surroundings are doing work on the system, this can be accomplished by adding tiny weights to a piston very gradually at a sequence of piston elevations. Or, heat can be transferred from the surroundings to the system by using a gradual sequence of constant temperature reservoirs at slightly different temperatures. Another key feature of an overall reversible process is that both the system and the surroundings can be returned to virtually their original states by running the process in reverse. This would not be the case if the system experienced an internally reversible process, but not the surroundings. And, it would not be the case if neither the system nor the surroundings experienced an internally reversible process.
FAQ: Reversible Processes Explained: Entropy, Time, & More
1. What is a reversible process?
A reversible process is a thermodynamic process that can be reversed by infinitesimally small changes in the surrounding conditions, resulting in the system returning to its initial state. In other words, the system follows the same path in reverse when the process is reversed.
2. How is entropy related to reversible processes?
Entropy is a measure of the disorder or randomness of a system. In a reversible process, the entropy of the system remains constant as the system returns to its initial state. This is because the reversible process does not increase the disorder or randomness of the system.
3. Can all processes be reversed?
No, not all processes can be reversed. Only processes that are thermodynamically reversible can be reversed. In thermodynamics, a reversible process is one that does not increase the total entropy of the universe.
4. How does time play a role in reversible processes?
In reversible processes, time is considered to be reversible. This means that the process can be run forward or backward in time, resulting in the same outcome. This is because the process is not dissipative and does not generate irreversible changes in the system.
5. What is an example of a reversible process?
An example of a reversible process is the Carnot cycle, which consists of two isothermal (constant temperature) and two adiabatic (no heat transfer) processes. In this cycle, the system goes through a series of reversible changes and returns to its initial state, with no net change in entropy.
