Revolving regions horizontally and vertically
  • Thread starter Thread starter Blonde1551
Blonde1551
The question asks me to revolve the the region bounded by the graphs y=√X y=0 and x=3 around a) the line x=3 and then b) around the line x=6
I know I am supposed to use the disk method or the washer method for this, which is ∏ ∫ R(y)^2-r(y)^2 from y=c to y=d.
for a, I set up R(y)=y^2. I set up the integral from y=0 to y= √3 ∏ ∫(y^2)^2
but when I plugged in the values I got 9.79 units cubed. In the back of my calculus book, however, it gives a different answer. I can't figure out what I did wrong.
For b, I set R(y)=6 and r(y)=(6-y^2). I set up the the integral from y=0 to y=√3
∏∫6^2-((6-y^2)^2)
I got an answer of 55.5 units cubed. Again, this was not the correct answer given to me in the back of my book.I can't figure out what I did wrong. Any help would be greatly appreciated.
For a, you don't quite have the correct value for the radius. R(y) = y2 is correct for the function, but remember that if you're revolving around x = 3, then the radius is going to be the distance between R(y) and 3.
For b, I think it's the same type of thing. The outer radius should be the distance between x = 6 and R(y), and the inner radius should be the distance between x = 6 and x = 3 (which is the inner boundary).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
