Rewriting a base; Formula of a Reciprocal Function
To convert the function y = 6*e^0.4x to the form y = at^b, it is noted that this transformation is not possible as it changes an exponential function into a power function. The discussion also addresses a second problem involving data points for concentration over time, where the goal is to derive the concentration equation 1/(a+bt) from the given data. Participants suggest graphing the data to determine coefficients a and b, but finding a clear method remains challenging. The confusion arises from the nature of the functions involved, emphasizing the distinction between exponential and power forms. Overall, the participants seek clarification on these mathematical transformations and their implications.
ryao3688
I have a function, y = 6*e^0.4x. How would I convert the regular form, y=a*e^bt to the form y= at^b?
y = 6*e^0.4x
I've tried to take the log of both sides, but if I do that, then "y" becomes a log, and I can't remove that "log*y" unless I put the "base" of the formula back down.
And another quick problem:
I have a set of data, t and C (hours and concentration; g/L, respectively). Somehow, by using that data, I can solve for the concentration equation, 1/(a+bt).
Given data:
t (h) 1.0 2.0 3.0 4.0 5.0
C (g/L) 1.43 1.02 0.73 0.53 0.38
Concentration equation, 1/(a+bt).
Not a clue;I'm supposed to find the coefficients of the concentration equation by graphing the data that was received. I've tried to graph a graph of C vs. T, and tried to take the reciprocal of that equation, but it didn't work. I'm supposed to plot the above data in such a way, that the coefficients of the concentration formula can be solved. Any ideas on how I should go about finding the a/b values for the formula?
Thanks in advance for your assistance.
for your first question:
let's say
A = e^a
then
e^{ab} = (e^a)^b = A^b
does that help?
Thanks Wukunlin, but I know I can combine e with its exponent.
Let me just replace that "x" with "t".
Ie: y = 6e^0.4t can be written as y = 6(1.4918...)^t - I need to find a way to get the "t" next to the base, and somehow get the base as the exponent - in the form y = at^b. I'm just confused about how I should go about doing this.
as far as I know that is impossible. What that does is turning an exponential function into a power function.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
