Calculating Covariant Riemann Tensor with Diag Metric gab
In summary, the steps are as follows:- Substituting the relevant Christoffel Symbols into R0101=g00(∂0(Γ011+Γ111)-∂1(Γ001+Γ101)+(Γ000+Γ001+Γ100+Γ101)(Γ011+Γ111)-(Γ010+Γ110+Γ011+Γ111)(Γ001+Γ101)) =ev(∂t(½eλ-v(∂λ/∂t) + ½λ') - ∂r(½v'+
CharlotteW
Using Ray D'Inverno's Introducing Einstein's Relativity. Ex 6.31 Pg 90.
I am trying to calculate the purely covariant Riemann Tensor, Rabcd, for the metric
gab=diag(ev,-eλ,-r2,-r2sin2θ)
where v=v(t,r) and λ=λ(t,r).
I have calculated the Christoffel Symbols and I am now attempting the solution using
Rabcd=gae(∂cΓedb-∂dΓecbecfΓfdbedfΓfcb)
With e and f as summation indices I have assumed that where the e and f occur in the same Christoffel symbol a summation of all Christoffel symbols, of all combinations of the two variables, should be summed.
For R0101 I have the equation to be
R0101=g00(∂0011111)-∂1001101)+(Γ000001100101)(Γ011111)-(Γ010110011111)(Γ001101)
Yielding the solution
R0101=(1/2)eλ(∂2λ/∂t2) - (1/4)eλ(∂λ/∂t)(∂v/∂t)-(1/4)eλ(∂λ/dt)2-(1/2)evv''-(1/4)ev(v')^2-(1/4)evv'λ'-(1/4)ev(λ'(∂v/∂t)-(∂λ/∂t)v')
where ' represents ∂/∂r.
The only term that is not in the solution given in the textbook is -(1/4)ev(λ'(∂v/∂t)-(∂λ/∂t)v') .
The relevant Christoffel symbols for R0101 are
Γ000=1/2 (∂v/dt) , Γ001=1/2 v'
Γ011=(1/2)e(λ-v)(∂λ/∂t) , Γ100e(v-λ)v'
Γ101=(1/2)(∂λ/∂t) , Γ111=(1/2)λ'I feel like I'm missing something rather simple as I have yet to come across a thread or example where the covariant Riemann Tensor has been calculated and the workings have been displayed. I may of course be using the wrong search terms for finding such a thing.
Can you fill in the steps that are covered by the words 'yielding the solution'?
Your presentation of the formula for the Riemann tensor in terms of Christoffel symbols is correct, but to check the process by which you reach your solution, without your providing any steps, would require any helper to do the entire problem themself.
If you can write down your steps, it shouldn't be too hard for somebody to find where it goes wrong - if indeed it does (textbook answers sometimes contain errors).
Thank you Andrew.
To expand on the 'Yielding the solution' part the steps in between are
substituting the relevant Christoffel Symbols into
=ev(∂t(½eλ-v(∂λ/∂t) + ½λ') - ∂r(½v'+½(∂λ/∂t) +(¼eλ-v(∂λ/∂t) + ½λ')(½(∂v/∂t) + ½(∂λ/∂t)) - (½v' + ½(∂λ/∂t)(½v' +½λ'))
Multiplying out bracket
R0101==ev(½eλ-v(∂2λ/∂t2) - ½eλ-v(∂λ/∂t)(∂v/∂t) + ½eλ-v(∂λ/∂t)2 + ½(∂λ'/∂t) -½v'' - ½(∂λ'/∂t) + ¼eλ-v(∂λ/∂t)(∂v/∂t) + ¼eλ-v(∂λ/∂t)2 + ¼(∂v/∂t)λ' + ¼λ'(∂λ/∂t) - ¼v'2 - ¼v'λ' - ¼(∂λ/∂t)v' - ¼(∂λ/∂t)λ')
Then I collected like terms to get my final solution stated in the post.
It looks like the signs of the two components of the non-matching term in the OP are opposite from the signs those components have in post 3.
It's a bit hard to be sure because the post is very hard to read since there is no latex used and no differentiation of bracket sizes to clarify where expressions for terms and factors begin and end.
If you know latex, it would help greatly if you could post your formulas using that. The only difference between this forum's latex and the standard is that in-line formulas use two consecutive # symbols as delimiters for the beginning and end of code, rather than the usual single $.
Also, you have a ##\tfrac{1}{4}## coefficient in the following line in post 3:
All numeric coefficients should be ½ prior to multiplying out brackets.
I will try using latex once I can get to my laptop. :)
Thank you for your help so far.
1. What is the purpose of calculating the Covariant Riemann Tensor with Diag Metric gab?
The Covariant Riemann Tensor with Diag Metric gab is used in mathematics and physics to describe the curvature of a space with diagonal metric. It is an important tool for understanding the geometry and dynamics of a space, and is particularly useful in the field of general relativity.
2. How is the Covariant Riemann Tensor with Diag Metric gab calculated?
The Covariant Riemann Tensor with Diag Metric gab is calculated using a mathematical formula involving the partial derivatives of the metric tensor. The specific formula used depends on the dimensionality of the space being studied, but it is typically a complex and time-consuming process.
3. What information does the Covariant Riemann Tensor with Diag Metric gab provide?
The Covariant Riemann Tensor with Diag Metric gab provides information about the curvature of a space with diagonal metric. It contains components that describe how the space is curved in different directions, and can also be used to calculate the curvature at a specific point in the space.
4. What are some real-world applications of the Covariant Riemann Tensor with Diag Metric gab?
The Covariant Riemann Tensor with Diag Metric gab has many real-world applications, particularly in the field of general relativity. It is used to describe the curvature of spacetime in Einstein's theory of general relativity, and is also used in the study of black holes, gravitational waves, and the expanding universe.
5. Are there any limitations to using the Covariant Riemann Tensor with Diag Metric gab?
One limitation of the Covariant Riemann Tensor with Diag Metric gab is that it can only be used to study spaces with diagonal metric. This means that it is not suitable for studying more complex spaces with non-diagonal metrics. Additionally, the calculation process can be very complex and time-consuming, making it difficult to use in certain applications.
