Solve Rigid Body Collision: System Approach w/Cons. Angular Momentum
A rigid body collision problem can be solved using a system approach by applying the conservation of angular momentum about a fixed point, such as the center of gravity of one of the bodies involved. The equation M = d[H]/dt is applicable when considering angular momentum about a point fixed in a massless extension of a rigid body or its mass center. Torque, defined as τ = dL/dt, is valid for any axis, but the equation τ = Iα holds true only for axes through the center of mass or center of rotation. This means that while total angular momentum can be conserved in two-body collision problems, careful consideration of the reference point is essential. The discussion emphasizes the importance of using appropriate axes for accurate calculations in rigid body collisions.
anandvineet27
under what conditions can a rigid body collision problem be solved using a system approach, (i.e by using the conservation of angular momentum of the two rigid bodies about some point)
the equation M=d[H]/dt is only valid when M and H are taken about a point fixed in a massless extension of a rigid body or its mass center. Yet for two-body collision problems, I have seen the total angular momentum being conserved about some point,( say, if a ball collides with a rod, then the cg of the rod).Is this approach valid?
welcome to pf!
hi anandvineet27! welcome to pf! :smile:
torque = rate of change of angular momentum (τ = dL/dt) is valid about any axis :wink:
(however, τ = Iα is valid only for an axis through the centre of mass or centre of rotation)
only valid about axes fixed in an inertial space.
yes :smile:
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
