Volcano said:
Unfortunatly. I don't have a ripple tank.
Are you planning to have one available or is this a thought exercise?
The amount of refraction depends on the change in wave speed. In deep water (Depth is more than one wavelength) the speed is only dependent on wavelength. In shallow water, the speed doesn't depend on wavelength and it is totally dependent on depth.
The maths of this is horrible, if you don't like that sort of thing so avoid thinking about what happens in 'moderate depths'. The formulae at the bottom of
this reference, sum it all up. A practical demonstration of all this can be seen on any shelving beach with waves arriving at an angle to the normal. You can see small ripples moving very slowly, compared with the main set of waves arriving (deep water condition for the short waves) a range of shorter waves can be
seen to travel at different speeds. You can see the longer waves being bent more and more towards the beach as the water gets shallower and, eventually, they arrive almost at right angles to the shore as the depth tends to zero. Longer and shorter waves tend to behave the same way near the shore. No equipment but eyeballs needed here and you get a nice day out at the seaside, too.
In a practical (school-type) ripple tank, the depth of water is such that what you see is the 'shallow' condition. The wave making device tends to be a bar that is attached to an eccentric pulley on a small motor. This is a poor system for exploring a range of frequencies. It's all held up by rubber bands and you cannot get the motor make the bar oscillate in the water at any frequency other than the one the maker wants you to. If you use a better 'actuator' you can make waves of many frequencies and take it into the 'deep water' condition. Also, a stroboscope can allow you to see the wave patterns, frozen.
EDIT: PS I did a lot of experimenting with a tatty School ripple tank and used a signal generator to move a piston at a range of frequencies and a strobe. I showed the other staff just what it would do but, unfortunately, the setup was too hard to drive for yer average secondary Science teach and I never got to present it to kids. I then realized that 'too much' Science is not always a good thing in teaching.
