What Is the Name of the Curve Traced by a Ball on a Ripple Wave?
  • Thread starter Thread starter topito2
    Ripple Wave
The equation describing the shape of a ripple wave is often related to the Schrödinger Wave equation, which serves as a good approximation for water surface waves. The curve traced by a ball rolling along the ripple wave is suggested to resemble an ellipsoid. Oceanographers typically utilize a "linear model" for wave analysis, but this model has limitations in extreme conditions. The discussion highlights the complexities of accurately modeling wave shapes and the paths of floating objects. Understanding these dynamics is crucial for advancements in oceanography and wave physics.
topito2
Do you know if there is any name for the equation that describes the shape of a ripple wave? An example of that kind of wave can be found at http://en.wikipedia.org/wiki/Image:Elliptical_trajectory_on_ripples.png.
My question is: what would you call the curve traced by the ball rolling along the ripple wave curve?
The best approximation to water surface waves currently in use is a version of the Shcrodinger Wave equation.
Oceanographers often use something called the "linear model" but it fails in extreme cases.
I believe that that path followed by a floating object is nearly an elipsiod.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
